I need to install some files to a directory retreived from doing an AppSearch in the
registry. How do I create a diretory entry that has the path that a property holds?
In AppSearh table, I have:
| Property | Signature_ |
| DT | AppReg_dt |
In RegLocator I have something like:
| Signature_ | Root | Key | Name | Type |
| AppReg_dt | 2 | Software\... | | 0 |
In the Directory table:
| Directory | Directory_Parent | DefaultDir |
| DT | TARGETDIR | DT |
I had that working for a while but all of a sudden I am getting "Internal error 2705"
error! Weird thing is that if I run the installer INSIDE Wise then I don't get that error
but if I run it outside (compile the installer with the coomand-line WfWI.exe) then I
get that error...
Any thoughts?
THANKS!
Create a directory entry from a property?
quakey
, Nov 30 2004 03:56
Posted 30 November 2004 - 08:57
Did you validate your msi file?
Do you initialize the property, in case the registry entry is not found?
Posted 30 November 2004 - 09:38
| QUOTE (Stefan Krueger @ 2004-11-30 08:57) |
| Did you validate your msi file? Do you initialize the property, in case the registry entry is not found? |
Let's assume the properties are all initilized and the registry entries are present, is this
the correct way to create a direcotry entry from a property (which holds the path read
from the registry via AppSearch)?
Thanks.
Posted 30 November 2004 - 17:52
I usually perfer to use a different property for the search, and then call a type 51 (set a directory) custom action with the result of the search.
Posted 14 December 2004 - 13:16
there is a wise article, which explains how to use a custom action (custom action 51 is the right one, Mr Krueger said it before) for your problem. It´s on http://www.wise.com/...folder directly
Hope, it helps,
NewOrder
Hope, it helps,
NewOrder
