Hi.
I shiped an installation package for my product last week. Now I have to implement the upgrade. I read a lot of articles and docs and I now know which GUID values to change, how to populate the upgrade table,...
However I'm concerned about the upgrade. When testing with logging option enabled (/L setting to the .msi file) I found that the upgrade first fires up the uninstall and then the installation. This is ok - I expected this. The problem is that during uninstalation I didn't see the property, which I set in upgrade table, set ... the property apears only during the install.
Explanation:
I have to remove all files when I do an 'real' uninstall (REMOVE=ALL). On the other hand I have to remove only the installed files (not user files) when I'm doing an upgrade of my product. How can I identify the upgrade?
BTW: To avoid another posting ... I'm using the below properties to identify some processes ... please correct me if there is an error ... also give me any aditional sugestion.
- Installation: property 'not Installed'
- Uninstallation: property 'REMOVE=ALL And Installed'
- How to identify the modify (add component)
- How to identify the repair
Another question:
How to upgrade only installed components?
10x a lot and regards,
Dezo
Identifying the upgrade - please help
damird
, Jul 05 2003 06:54
Posted 05 July 2003 - 09:59
You can use the UPGRADINGPRODUCTCODE property.
See help topic "Conditional statement syntax" for information how to detect if a certain component or feature is being added or removed in a maintenance install.
