What I had wanted to accomplish - to change my patch displayname in Add/Remove applet to customized text other than the default "Update" by Windows Installer, given the "Show Updates" checkbox is checked in Add/Remove.
What I did - included MsiPatchMetadata table in to my .pcp file and populated properties such as DisplayName and MoreInfoURL, etc. with certain string values.
Created .msp file with MsiMsp.exe.
What I found after having applied the patch - the patch name was still "Update" in the Add/Remove and all other customized properties not shown at all!
Did anybody encounter the same problem before? How did you solve it?
Or
Does anybody knows what could have been wrong with my approach to change the default patch install information?
Any hint will be appreciated.
D.X.
MsiPatchMetadata Table and DisplayName
dxue
, Dec 16 2005 20:13
Posted 19 December 2005 - 08:46
If I understand, you've include the table MsiPatchMetadata into the .pcp and you've create a patch from this .pcp. That's wrong. You've to options to get the wished behaviour.
1. You'll include the poulated table MsiPatchMetadata directly into the .msp-File with Orca or
2. you'll include the populated table PatchMetadata into the .pcp-File. This table content is copied to MsiPatchMetadata while patch creation.
Andreas
Andreas
Andreas Kerl
Inside Windows Installer 4.5
ISBN 3-86645-431-7
