I have a dialog with a RadioButtonGroup on it with two radio buttons. It has a property called BACKUPDATABASERBG. In the property manager, I default this property to "Yes"... the other option is "No". I then have a Deferred Custom Action that is suppose to run when BACKUPDATABASERBG="Yes". The problem is it is always evaluating to Yes no matter what is chosen. I'm not sure why this is. I've used RadioButtonGroups in the past in deferred custom actions.
Problems with RadioButtonGroup properties
Josh Luth
, Dec 02 2003 23:16
Posted 03 December 2003 - 10:16
What are the values associated with the two radio buttons? What happens if you set it to No by default in proeprty table? Are you logged on as administrator? If not: is the property BACKUPDATABASERBG listed in SecureCustomProperties?
