Hi.
I must reedistruibuite a project with a motitude of subproject,that are standalone programs that run indipendently.
I think to divide this installation with a msi for each subproject,and a base setup.exe that launch the msi subproject with an interface.
I think to launch those msi with a parameter that is the targetdir , but i not able to comunicate at all the msi the targetdir base.
thanks
multiple msi
giugio
, Oct 25 2007 12:54
Posted 25 October 2007 - 15:34
Are you using INSTALLDIR?
MSIExec /i [whatever.msi] INSTALLDIR="C:\Program Files\Whatever" [other swicthes]
Posted 26 October 2007 - 18:07
This might be off the original subject, but are you trying to launch multiple MSIs from within another MSI? I don't think that's supposed to work. If you're wanting to launch the MSIs from an InstallScript (or other non-MSI technology) you would use the command line specified by VBScab for each one.
TargetDir is usually used in Installscript projects and INSTALLDIR is used in MSI projects. I think they roughly translate into the same thing, although I believe there are some gotchas when using an Installscript MSI project.
-- spdygnlz --
