I've got a project that I rewrote for Basic MSI (it was an ancient InstallScript v6 or so). One of the requirements is to have the user prompted for a password in order to complete the uninstall. No password, or wrong password should abort the installer.
In InstallScript world, it worked fine, but as a basic MSI, I can't figure out how to insert a dialog (to get the password) between clicking "remove" on the Add/Remove Programs dialog and the "Are you sure you want to remove [PRODUCT]" dialog.
Everything works correctly when uninstalling using setup.exe.
Any and all help/suggestions would be greatly appretiated.
Thanks.
If it matters, the target systems are XP, Server2003, Server2008. I'm using InstallShield 2009.
Password protect uninstall
jspelbring
, May 24 2010 20:20
Posted 25 May 2010 - 16:00
Since the UI sequence doesn't run in this situation, you coudl instead insert a custom action in the execute sequence that displays a dialog.
Posted 25 May 2010 - 16:03
Stephan,
That was what I thought, but even in the execute sequence, it doesn't want to show up. I even created a custom action that just pops up a message box with no conditions. I added it to both the UI and Execute sequences. It shows up during install, but not during uninstall via Add/Remove Programs.
Posted 25 May 2010 - 18:41
Then you should generate a log to see why your custom action doesn't fire.
Posted 14 June 2010 - 12:16
Can you add the Custom action after InstallFinalize action and check it once?
