Odd Installer behaviour
Posted 07 November 2003 - 11:09
The software installs fine and they can then use it without a problem.
They then shut the computer down and log in as the same user. When they start our software up the windows installer kicks in again and runs through the configuration process.
Now I would understand if they had logged in as a different user or if they had deleted user settings or something but in this case its the same user with no modifications.
Anyone got any suggestions?
Reflex.
Posted 07 November 2003 - 12:17
Posted 07 November 2003 - 15:56
All that is there is "<Product> configuration completed successfully".
Posted 07 November 2003 - 18:30
Posted 10 November 2003 - 11:03
please excuse the ignorance, but how would I set the installer to log using the registry?
Posted 10 November 2003 - 11:06
I do know how to enable normal logging, I normally use te group policy editor rather than edit raw registry values.
Kind Regards
Reflex.
Posted 17 November 2003 - 10:55
Can I attach the log file here?
Kind Regards
Reflex
Posted 18 November 2003 - 00:40
Other things I have seen: components pointing to empty folders, a component pointing somewhere in the temp folder, a keypath set to a location in the registry where the user does not have write access, roaming profiles (no idea why, but I have had mysterious self repairs kick in when using roaming profiles with no clear cause), faulty merge modules: http://forum.install...?showtopic=8723, etc... The log file would be useful.
Posted 18 November 2003 - 10:31
Below are the opening lines of the Windows Installer log, maybe someone can spot something that I am missing.
Thanks for all your help so far,
Reflex.
-----Windows Installer Log-----
MSI © (34:94): Resetting cached policy values
MSI © (34:94): Machine policy value 'Debug' is 0
MSI © (34:94): ******* RunEngine:
******* Product: c:\Temp\_Sfx922\Product.msi
******* Action:
******* CommandLine: **********
MSI © (34:94): Machine policy value 'DisableUserInstalls' is 0
MSI © (34:94): SOFTWARE RESTRICTION POLICY: Verifying package --> 'c:\Temp\_Sfx922\Product.msi' against software restriction policy
MSI © (34:94): Note: 1: 2262 2: DigitalSignature 3: -2147287038
MSI © (34:94): SOFTWARE RESTRICTION POLICY: c:\Temp\_Sfx922\Product.msi is not digitally signed
MSI © (34:94): SOFTWARE RESTRICTION POLICY: c:\Temp\_Sfx922\Product.msi is permitted to run at the 'unrestricted' authorization level.
MSI © (34:94): Cloaking enabled.
MSI © (34:94): End dialog not enabled
MSI © (34:94): Original package ==> c:\Temp\_Sfx922\Product.msi
MSI © (34:94): Package we're running from ==> c:\Temp\166a5.msi
MSI © (34:94): APPCOMPAT: looking for appcompat database entry with ProductCode '{BC29B6AE-248C-40F7-BD5C-C2BE167DBC33}'.
MSI © (34:94): APPCOMPAT: no matching ProductCode found in database.
MSI © (34:94): Transforms are not secure.
MSI © (34:94): Command Line: REINSTALL=ALL REINSTALLMODE=vomus CURRENTDIRECTORY=C:\WINDOWS\System32 CLIENTUILEVEL=0 CLIENTPROCESSID=308
MSI © (34:94): Product Code passed to Engine.Initialize: '{BC29B6AE-248C-40F7-BD5C-C2BE167DBC33}'
MSI © (34:94): Product Code from property table before transforms: '{BC29B6AE-248C-40F7-BD5C-C2BE167DBC33}'
MSI © (34:94): Product Code from property table after transforms: '{BC29B6AE-248C-40F7-BD5C-C2BE167DBC33}'
MSI © (34:94): Product registered: entering maintenance mode
MSI © (34:94): Entering CMsiConfigurationManager::SetLastUsedSource.
MSI © (34:94): Specifed source is not already in a list.
MSI © (34:94): User policy value 'SearchOrder' is 'nmu'
MSI © (34:94): Machine policy value 'DisableBrowse' is 0
MSI © (34:94): Machine policy value 'AllowLockdownBrowse' is 1
MSI © (34:94): Adding new sources is allowed.
MSI © (34:94): Package name retrieved from configuration data: 'Product.msi'
MSI © (34:94): Determined that existing product (either this product or the product being upgraded with a patch) is installed per-machine.
MSI © (34:94): Note: 1: 2262 2: AdminProperties 3: -2147287038
MSI © (34:94): Machine policy value 'DisableMsi' is 0
MSI © (34:94): Machine policy value 'AlwaysInstallElevated' is 1
MSI © (34:94): User policy value 'AlwaysInstallElevated' is 1
MSI © (34:94): Product {BC29B6AE-248C-40F7-BD5C-C2BE167DBC33} is admin assigned: LocalSystem owns the publish key.
MSI © (34:94): Product {BC29B6AE-248C-40F7-BD5C-C2BE167DBC33} is managed.
MSI © (34:94): Running product '{BC29B6AE-248C-40F7-BD5C-C2BE167DBC33}' with elevated privileges: Product is assigned.
Posted 18 November 2003 - 11:38
If so, try logging on as a local administrator... does the MSI still self-repair repeatedly?
If this works, I'll explain what I think is happening later.
Posted 18 November 2003 - 11:41
Posted 18 November 2003 - 11:44
Due to the time differences the client is getting rather antsy and we would rather have some kind of explanation the next time we talk to them.
At least I will have the course of the day to have a look at other possible scenarios.
The support guys I am working with havent made any indication that it carries on doing the self-repair.
Posted 18 November 2003 - 13:12
The installer uses different security contexts depending on the actions it's performing, the privileges of the user, policies in force, etc.
When an MSI advertisement is invoked by the shell (when you use an advertised shortcut for example), the installer will check the keypaths for all components within the feature that is to be used. For "per machine" managed applications (installed by an administrator), the installer normally does this under the "system" security context.
When an MSI has been installed "per machine" by a non-admin user under the "AlwaysInstallElevated" policy, the runtime component checking appears to occur under the user's security context. Because of this, resources that are actually installed may not be seen because the user doesn't even have "read" NTFS permissions t that resource (eg: a file in another user's profile - hence the requirement to always use registry keypath's for user components). Because the resource is deemed "missing", the component is deemed broken, and the feature is repaired.
You should however find "application" event log entries (EVENT ID 1004) stating that the resource is missing.
A local administrator will not normally experience the problem because he most likely has at least "Read" NTFS permissions to the resource acting as keypath for the component.
Personally, I think this is a bug.
