In Windows ME,
Sometimes, when I install my product, the installshield pops this error message "MSIEXEC.EXE file is linked to missing export MSI.DLL:222"
I have known this problem is caused by conflict by Installer 1.2 with Installer 2.0.
I think this conflict is solved in other OS , Installshield uses own Install2.0 (msi.dll for 2.0) and suppress reboot. after reboot ,The Windows is updated with installer2.0.
But Why do the problem still appear in Windows ME why???
I know that the system will be ok after I push OK and reboot .
But My customer don't see any error message !!
someone saves me .
It is emergency!!!!
thanks thanks thanks
MSIEXEC.EXE file is linked to missing export ...
Molvse
, Jul 11 2003 03:53
Posted 09 September 2003 - 04:10
yeah it is a known issue ....
The user can be asked to upgrade the msi by running teh instmsi applications first, before running your setup.
That is the recommended way in even the Microsoft products.
Another work around that can be provided is to write a wrapper to the Setup.exe generated.
As a standard, this wrapper exe can be named as setup.exe while the original setup.exe can be named say run.exe.
This wrapper exe should enumerate this error windows title ie "Error Starting Program" and then when it finds it should send an OK message so that it gets closed even without the user seeing it. This wrapper should also be calling the actual setup.exe now renamed as run.exe
I hope this helps
I hope this helps
