hi friends
I have windows 2000 sever upgraded from windows nt 4 server . Problem starts when i try to install antivirus , a messge appears "This can only be installed on service pack 4 or better" . when i started installation of service pack 4 following messge occurs
"The procedure entry point setupapi.CM_Disable_Devnode could not be located in the dynamic link library CFGMR32.dll
Plz check it out
Thanx
Installation of Sevice Pack 4
zubairkhan
, Mar 18 2004 08:49
Posted 27 April 2004 - 17:08
I would try to replace the "cfgmgr32.dll" to a better version that has this function exported.
You can do that by using "depends" utility,to view if the DLL has this particular function exported or not.
OR one clear way would be to upgrade to Service Pack 3 (which I'm sure has latest Dll's necessary for SetupApi.) and then upgrade to Service Pack 4...just a try nothing to loose.
L
L
