To get a video to run off the CD, I use a string value
[SOURCEDIR]\Demos and set the path in the registry.
The [SOURCEDIR]\Demos resolves to (say) D:\Demos in the registry and the video runs from the CD ROM drive.
The problem is that when the repair option in the dialog is used, the drive letter 'D:\' disappears from the registry and I'm left with 'Demos'.
I have tried changing the case to [SourceDir] and have also tried using [SETUPEXEDIR]. Both enter the correct drive letter in the registry but the drive letter disappears after a repair.
Any suggestions?
SOURCEDIR & it's value in registry after a Repair
Tyler Curtis
, Jun 22 2005 01:10
Posted 22 June 2005 - 16:21
SOURCEDIR only gets set during an install. It gets set by the ResolveSource action. If you try to run ResolveSource on anything other then an install, you will usually get a prompt asking for the CD media.
Instead of using SOURCEDIR get the value from the registry instead. Or if you don't need the value to repair the registry, jsut set a condition on that registry action to only be set during an install.
Posted 22 June 2005 - 19:05
I'll go after it this way,
Thanks for the help!
Thanks!
Tyler Curtis
Craftsman Book Company
Tyler Curtis
