I am writing an installation where the target directory must be a specific name directly off of a local drive root. So instead of the normal DestinationFolder Dialog, I have substituted my own dialog with a listbox containing suitable paths based on whatever drives are available on the system. I have been unable to set the target path, and the installation always goes to the C drive, which is the default INSTALLDIR at build time. I am able to update an edit control based on the user's selection, but cannot call SetTargetPath based on that control's contents. I get a fatal error every time! I realize that SetTargetPath (Event) is really expecting a PathEdit Control (Argument)which works alongside DirectoryLists, etc... I have even scripted a CA that calls MsiSetTargetPath to change the TARGETDIR which doesn't error, but doesn't change the target drive from C: Has anyone successfully set a target path that wasn't selected through normal "channels"?
This is driving me insane!!!
Thank you for listening...
SetTargetPath results in Error!
Gavin
, Apr 12 2002 01:29
Posted 15 April 2002 - 19:51
I got it fixed...Duh!!!
In case anyone can use this...
Create a SP:
Type: 35 (DirectoryTable)
Source: TARGETDIR
Target: [TARGETPATH] (The user selected destination)
I put a DoAction that calls the SP in the event handler for the Next button before the call to NewDialog.
It works great. Turns out I worked myself into a frenzy searching for something that was right in front of my face.
Create a SP:
Source: TARGETDIR
