I need to stop MSSQLServer before uninstalling MSDE 2000 merge module. Which is the best way to do this?
I tried calling LaunchAppEx:
szProgram = "C:\\Programmi\\Microsoft SQL Server\\80\\Tools\\Binn\\scm.exe";
szCommand = " -Action 6 -Service MSSQLSERVER";
LongPathToQuote(szProgram,TRUE);
LongPathToQuote(szCommand,TRUE);
_LaunchAppEx(szProgram,szCommand,WAIT,SW_SHOWNORMAL,-1,nvExitCode);
with these instructions I obtain that scm executes as if without command line parameters, it shows that window with instructions on using it...
I don't know if this is a right way to solve my problem.
Could someone help me, please?
Stop MSSQLServer before uninstalling
snow
, Dec 10 2002 10:40
Posted 11 December 2002 - 18:35
LaunchAppAndWait("net", "stop MSSQLServer /y",WAIT);
You can try this code. The /y is to address any confirmations that might be asked during the shutting down of the server. The downfall to this method is that a DOS window will appear but it closes itsself. There are ways of hidding the process but they include creating a c++ dll and using the creatprocess function which allows you to hide windows. Becarful to take into consideration that a user may have more than one instance of SQLServer installed and to shut down the appropriate one best way to get that info is to ask the user.
Posted 12 December 2002 - 08:16
cmcintosh,
thank you for answering. The solution you suggested me, works fine with Win2K but not in Win98.
I testsed it from the command line, but I get this error:
"Error 2185: Service name is not valid."
Any ideas?
Any ideas?
Posted 23 January 2003 - 12:42
Try adding the Silent option.
szCommand = " -Action 6 -Silent 1 -Service MSSQLSERVER";
It should fix it.
It should fix it.
Posted 23 January 2003 - 12:47
You may need to stick a space in at the start.
" -Action...
I use the scm command and it work smoothly on win98.
" -Action...
