How would you change Directory Property value when installation re-ran from ARP MODIFY option?
I would like to re-set the Directory property so that any subsequent MODIFY or repair will remember the new value. Currently I set with Session.Property("MyDirproperty") = szTheValue but It doesn't seem to store that value in Cache or Source MSI. It seems like it only changes the value temp in memory.
Thanks.
How would you change Directory Property Value
VILEPARLE
, Aug 26 2005 16:07
Posted 26 August 2005 - 22:15
Property values are not persisted. Just like a variable. If you want to prserve them you need to write them (to the registry for instance)
