Hello, I've been having trouble trying to override the OnNextDisk function. When I override the function, the whole installation gets hosed. First off, it asks for disk 2 when it doesn't need it yet. And then at the end of the installation, it asks for disk 2 for data3.cab (where it exists) and then when you enter disk 2 and EnterDisk returns a 1 (OK). Immediately after that, it throws a Feature Transfer Error and says the system cannot find data3.cab. All I'm using the OnNextDisk for is modifying the message in the EnterDisk pop up. It otherwise works fine without OnNextDisk, but when it comes to disk 2, it uses the default message. Any help on the proper way of overriding OnNextDisk? Currently my function looks like this:
function OnNextDisk(File, Disk, Path)
// variables declared here
begin
// according to the disk, an enterdisk() is called and the status is returned.
end;
Any help is greatly appreciated, thanks!
- Dan
OnNextDisk question
Zangow
, Mar 02 2006 16:27
Posted 13 March 2006 - 19:01
If this helps, this is what I have that hoses my installation:
// variable declarations
begin
NumToStr(svDisk, Disk);
if(!Is(FILE_EXISTS, Path ^ File)) then
VarSave(SRCTARGETDIR);
SRCDIR = Path;
StrSub(svDrive, SRCDISK, 0, 1);
svMessage = "Please insert disk " + svDisk + " into drive " + svDrive + ".";
nResult = EnterDisk(svMessage, File);
VarRestore(SRCTARGETDIR);
else
nResult = OK;
endif;
return nResult;
end;
begin
SRCDIR = Path;
else
nResult = OK;
endif;
return nResult;
end;
Posted 14 March 2006 - 13:03
I believe you need to add
Path = SRCDIR;
after EnterDisk.
Path = SRCDIR;
after EnterDisk.
