I have an installation program that has different paths depending on if a reinstall is being performed or a new installation. The way I have been testing the reinstall is by changing the package code and setting the CmdLine=REINSTALLMODE=vo REINSTALL=ALL in the setup.ini file. The problem is, I want the user to be able to double click Setup.exe whether it's a first time install or "upgrade". If it is a first time installation, the CmdLine is wrong (should be blank). How can I accomplish this?
I am using ISDev 7.02.
Thank you,
Joe
