As they say wrong things come in hand when you dont want it to.
We have a major release coming Friday and we are facing the following issue while Installing the application(MSI).
Please see the log file and please suggest any workarounds.
Note:
a)This happens only on certain systems and not all.
Sreenath
=== Logging started: 11/2/2007 18:40:57 ===
Action start 18:40:57: INSTALL.
Action start 18:40:57: ISMsiServerStartup.
Action ended 18:40:57: ISMsiServerStartup. Return value 1.
Action start 18:40:57: ISStartup.
1: The InstallScript engine version currently installed on this machine is adequate.
1: Event 'E4058265' is created
1: GetInstallDriver, Can not find InstallDriver in ROT table, Return Code = 0x800401e3
1: {CDDA9F0F-D899-4607-9207-6A93E2C15122}
1: Extract supporting files
1: Failed to extract _IsUser.dll, Ignore it.
1: Failed to extract IGdi.dll, Ignore it.
1: ISMsiServerStartup Failure, Failed to Initialize script support, Error = 0x80010105
1: MsiServerStartup failed. Abort installation.
Action ended 18:40:59: ISMsiServerStartup. Return value 1603.
Action ended 18:40:59: ISStartup. Return value 3.
Action start 18:41:02: ISCleanUpFatalExit.
1: Shutting down the PRC server...
1: RPC runtime reported exception 0x6ba
Action ended 18:41:02: ISCleanUpFatalExit. Return value 1.
Action ended 18:41:02: INSTALL. Return value 3.
MSI (s) (10:88) [18:41:02:874]: Product: XYZ -- Installation operation failed.
=== Logging stopped: 11/2/2007 18:41:02 ===
