Hi All,
InstallShield Suite project taking /Q as silent switch for silent install of MSI.
But, how can i change it to /QR.
Many Thanks,
Regards,
Y S Reddy.
Posted 13 August 2013 - 08:16
Hi All,
Many Thanks,
Regards,
Y S Reddy.
Posted 13 August 2013 - 09:02
In the package properties you can set the "MSI Silent Command Line"
Posted 13 August 2013 - 17:31
Hi Stefan,
Thanks for your quick reply.
I'll give a try tomorrow.
Regards,
Y S Reddy.
Posted 16 August 2013 - 13:03
Hi Stefan,
I tried to pass /QR in "MSI Silent Command Line", but Setup.exe is not installing the MSI.
If i don't pass anything then Setup.exe installing the MSI in quiet mode.
Is there any other way, where i can install MSI with /QR switch in InstallShield Suite project.
Please help me.
Many Thanks.
Best Regards,
Y S Reddy.
Posted 22 August 2013 - 11:58
You are right, I'm sorry for the confusion. Suite/Advanced UI projects are designed to show their own UI instaead of the individual packeages' UI. Here's a quote from the help:
Note that the Advanced UI or Suite/Advanced UI setup launcher automatically suppresses the user interface of .msi, .msp, and InstallScript package formats, in favor of the wizard interface of the Advanced UI or Suite/Advanced UI installation.
So why do you want to use /QR in the first place?
If you really need to, you shouldn't add the .msi as a package but instead the msi install's setup.exe, where you can freely configure the command line. Of course you lose the benefit of a global progress bar.
