Hello Everybody,
I want to install one of executable file from my install components as a service. I don’t know how InstallShield support for this? And how should I go about it? Also where can I found all information about it, in detail?
Ajay
Application as Service
pajaykumar
, Jun 12 2007 06:25
Posted 13 June 2007 - 18:01
Go to the component that includes the service file. Expand the tree view to get to the Advanced section. There are settings to create and start/stop services.
Posted 13 June 2007 - 18:38
Hi Stefan,
I'm also trying to install a Service using InstallShield 2008. Using "Components-->Advance Settings-->Install NT Services", I can able to install the Serice. By default the service being installed under the 'Local User'. To be installed under a specific User, I specify the Domain/Username under "Install NT Services', that also works. But my requirement is, the Domain/Username should be captured dynamically.
I come across few postings in this forum in which people suggested to make an entry in 'ServiceInstall' table in order to install a Service.
1.What is the difference between installing a Service using "Components-->Advance Settings-->Install NT Services" and "ServiceInstall" table and how to make an entry in "ServiceInstall" table?
2.How to get the Domain/UserName dynamically?
MShan
MShan
Edited by mshan, 13 June 2007 - 18:47.
Posted 13 June 2007 - 21:06
There's no difefrence. The "Install Services" view populates the ServiceInstall table. You can see all tables in the Direct Editor.
Try using a property in square brackets in the username field like:
[SERVICEACCOUNT]
where SERVICEACCOUNT is a property that the user enters in an edit box for instance.
[SERVICEACCOUNT]
Posted 13 June 2007 - 21:45
I use the [IS_NET_API_LOGON_USERNAME] property to populate the service RunAs account and it works great. Of course I have to include the LogonInformation dialog.
-- spdygnlz --
