When I install the product by selecting "complete" installation (via user interface: typical, complete, custom), everything installs fine.
On the other hand, when I try to do the same - and a previous version of the product is already installed - so, it's an upgrade - no feature or component gets installed. (Also no feature or component gets uninstalled.)
The log then reports:
Installed: Absent; Request: Null; Action: Null
for all components and features.
When I do the same upgrade by selecting some features in a "custom" setup, the features and components get installed resp. deinstalled fine.
When I do a fresh installation, selecting a "complete" setup, the files get installed, too.
[Product code and version number have changed between versions; upgrade code has remained the same; upgrade table is OK; (top-level) features are marked "required".
Everything worked with the previous versions of the setup program. I think all I've changed is introducing two command line parameters, conditionally adding a dialog form, and writing to the registry.]
- Why does a "complete" "upgrade" not install as supposed?
- Thank you for any piece of information or idea!
No upgrade when selecting "complete" installation
unwise.exe
, Jan 27 2003 15:22
