Hello,
does someone has got a solution to run RemoveExistingProducts in Maintenance Mode?
Thanks in advance!
Johannes
RemoveExistingProducts and Maintenance Mode
Johannes John
, May 13 2003 13:15
Posted 13 May 2003 - 18:19
RemoveExistingProducts only applies to Major Upgrades, so it will never be called in maintenance mode. What are you trying to do?
Posted 14 May 2003 - 08:13
Hello Stefan,
the global problem is, that each program of the product has to be upgraded only at users request. The simple solution would be a setup for each program, but that's too much ( about 30 programs ). And I want to avoid a program over the setups.
Therefor: Each setup with a new UpgradeCode and ProductCode,...
( if each component with a new code, I'm not sure )
And: The Upgrade Table with the list of the old setups and in the Remove Column a property with a list of features ( programs ) to be deleted in the old setup, depending on the actual installing programs/features.
This works when the second setup runs the first time.
But if the user installes a program/feature in maintenance mode, the program/feature of the first setup will not be removed, because of RemoveExistingProducts istn't running in maintenance mode ( described in description ).
To delete the contents of property "Installed" temporary is not the criteria for RemoveExistingProducts to run in Installation mode.
And CA 39 I don't get running at all, nor with REMOVE=x,y,z .
How to run RemoveExistingProducts in Maintenance Mode?
Thanks in advance!
Johannes
Thanks in advance!
Johannes
Edited by Johannes John, 14 May 2003 - 08:14.
Posted 14 May 2003 - 16:18
What you are tring to do is outside the concept of MSI. The best solution would probably be to create separate MSIs.
