I updated my software from 2.01 to 2.03. The splash bitmap that displays disables the next button. I can't go any further. I looked on installsite's web and found that instead of using closehandle in stream from binary custom action you should change to misclosehandle. I changed this but, It is saying unidentified when using misclosehandle. What header has to be added or put in. I believe this is what is causing my setup not to run. Normally what would happen is the splash bitmap would display and then run the custom action to stream from binary.
2.03 upgrade
laddison
, Mar 19 2001 19:37
