I have just created an ISScript custom action and the first line tries to get the SUPPORTDIR path.ie
MsiGetProperty(hMSI, "SUPPORTDIR", svSetupPath, nBufferSize);
The svSetupPath variable remains blank after the function is called.
In debug mode when I hover over "SUPPORTDIR" it has the correct path but svSetupPath is blank.
When I try leaving out the MsiGetProperty function and just
try svSetupPath=SUPPORTDIR;
svSetupPath remains empty even though when I hover over "SUPPORTDIR" it has the correct path in debug.
Any suggestions as to why its happening? I'm using IS 7.04
Problems with SUPPORTDIR
carrolls
, Sep 10 2002 17:56
Posted 24 July 2004 - 00:11
Make sure nBufferSize is atleast 128.
If nBufferSize is less than the length of SUPPORTDIR, then it will not work.
Posted 24 July 2004 - 06:29
Maybe try something like this:
function DoStuff ( hMSI ) NUMBER nvType, nBuffer; STRING szString; begin nBuffer = 256; MsiGetProperty ( hMSI, "ProductVersion", szString, nBuffer ); end; |
