I have a feature that consists of files from an IS 5.5 professional build.
When these files are moved to the target machine I want to fire off the Setup.exe file with a LaunchAppAndWait.
I then have a second feature that is about updating the sub installation that results from the first feature.
Unfortunately the LaunchAppAndWait is not waiting!
Is this because of the life span of the window that this function uses?
Any help greatly appreciated.
Marc
LaunchAppAndWait NOT waiting
Marc
, Mar 27 2002 20:05
Posted 27 March 2002 - 20:47
When launching the setup.exe of the IS5 setup, you should specify /SMS (case sensitive!
in the command line parameter
