two install directories
Posted 26 November 2001 - 15:34
thanks ...
Posted 28 November 2001 - 16:37
You may create a set of components for one dir (f.e. - default destination, [INSTALLDIR]) and other set of components with fixed path specified (f.e. [ProgramFilesFolder\Your second path]) as a destination dir. Or I've got something wrong ?
Posted 29 November 2001 - 08:47
Posted 12 December 2001 - 09:55
In the Advanced View add a Property of the same name and give it a default value.
In the Setup Design make sure your components are setup to install to this default dir., the components destination should look like {DIRVAR}default location i.e. {DIRVAR}C:\Program Files\My Second Install Dir.
The variable can now be accessed from Install script using MsiSetProperty.
Posted 18 December 2001 - 17:32
I solved such a problem on a different way.
I set INSTALLDIR for example c:\ and created then to subfolders. In Directory Table you can give your subfolders "names" so that you don`t need to write the path every time ( e.g. test stands for INSTALLDIR\\yourapp\\test)
Thomas
