I am trying to create a minor upgrade using the article "Minor and Major upgrading using IPWI" in the Tools and TIps section of this site.
I have changed package code and updated the product code from 5.01.0191 to 5.01.0192.
I need to update 7 files, 5 of which have updated file versions. In the setup.ini I use REINSTALLMODE=vaums so as all files will be reinstalled.
The problem is that only one file (one of the files where the version number has not changed) gets updated.
5 of the files are in one feature, the other 2 are in separate features. Each file is in its own component.
Also, uninstalling after the upgrade has been run does not remove any files.
I get this same behaviour on different machines.
Any help or suggestions as to what could be causing this behaviour would be much appreciated.
thanks,
David
