Some General information:
Build System: Win XP with SP1
Software: InstallShield Dev 7 SP4
Project: Standard
I'm doing a major upgrade that upgrades fine except for a singular issue, the application icon installed on the desktop and the icons created in the Start Menu\Program folder are removed after the installation is finished.
I'm creating the icons using the InstallScript AddFolderIcon() function. Presently, I call this function in the OnEnd() section of the script. So, it's supposed to be the absolute last thing InstallShield does. Originally I called it in OnFirstUIBefore(), then I tried it in OnFirstUIAfter(), but the behavior is the same in both of those places as it is when called from in OnEnd(). The install/upgrade completes, looks fine for a second as the Program Folder comes up from calling ShowProgramFolder(), then that same program folder just dissapears because InstallShield removed it! Just *poof*, gone.
Has anyone come across this problem when creating an install that does a major upgrade to installations of another version? If so, did you solve it? If so, how? If not, do you have any ideas other than that of using the Shortcuts/Folders pane?
It looks an awful lot like a bug with InstallShield. If so, I'd love to know a way to work around it.
Major Upgrade Works, But Removes All Shortcuts
Cookie Crumb
, Nov 26 2002 09:56
