I have a VC7 project which needs MFC70.DLL installed on the user's machine. When I include VC_MFC.MSM the MFC70.DLL gets installed in D:\ and not in the Windows System(32) folder. Does anyone have a clue why this is happening?
Thanks for your answer,
Joep
MFC70.DLL installed in D:\ ?
joepov
, Jun 26 2002 00:22
Posted 16 July 2002 - 22:52
Are you using Installshield Express or Developer to build your setup? If so you will have to:
1. Right click on the merge module and select Properties
2. Select [SystemFolder] from the dropdown for the Destination property
3. Close the property dialog, build and install
This is because the MFC7 merge modules use the ModuleConfiguration Table to decide where these files should be installed. Installshield Developer and Express don't support this table yet.
