Hello,
I am modifying an existing installation to which I need to add the functionality of installing different icons for different conditions being met in the installation. Has anyone ever played with this?
Discription: User 1 installs our Custom Radio Application under affiliate ABC. They get the icon that is associated with affiliate ABC. User 2 installs under affiliate XYZ and they get the icon that goes with affiliate XYZ. Does anyone know the best way to accomplish this?
Thank,
Robert Elliott
Install Different Icons For Diff. Conditions Met
elliottrb
, Jul 02 2002 23:16
Posted 02 July 2002 - 23:45
Use the
AddFolderIcon ( FOLDER_PROGRAMS ^ "Folders", "Manual" , svPath , TARGETDIR , "" , 0 , "" , REPLACE );
Look at the help for this function. you can specify which icon file you want to use. In your case, you can put in a condition and specify the things you need.
alex
alex
Alex Ferguson
www.SolimarSystems.com
