In a nutshell, I need to know if there is an easier way to change the value listed under "link to" in the IDE. Our environment has changed, and now I need to pull the majority of our installs 400+ files from a new area on the network. Right now, it is looking like I need to delete each of the files from the various components and add them back to change the "link to" value. This seems like quite a bit of work. Is there an easier way, or does anyone know of a tool that can automate this process.
Thanks for any help I might recieve,
Ryan
How can I change the "link to" value in the IDE
ryan h
, Oct 14 2002 21:12
Posted 15 October 2002 - 20:32
In general, path variables are intended to avoid this kind of trouble. You can automatically convert your static paths to valriables. Next time you simple mdofiy one variable to re-base all your paths.
