Patch only applies on second try
dalchri@hotmail.com
, Aug 27 2003 15:02
Posted 27 August 2003 - 15:02
I am trying to apply a patch. The first time that I apply the patch, I get the screen where it says that it is updating the program but it whips through the screen way too fast. After it completes, the update has not taken. However, when I open the program, again, I see a WI screen pop up very briefly and then disappear. The second time that I try to apply the patch, the installation screens take much longer to complete. This time I actually see the installation screens say "patching files" and "copying new files" just as they should. After the second attempt, the patch is completed successfully.
The problems gets even worse on NT. I cannot get the exact same msp patch to apply at all using the exact same starting msi.
I have authored previous patches that have not had this problem. The only thing that I can think of that is different is that in the previous patches, I did not use the ListOfPatchGUIDSToReplace property to remove the previous patches. That only worked with the first two patches though. This is the third in the series and I started getting error messages which I solved by entering the GUIDs of the previous two patches into the ListOfPatchGUIDSToReplace property.
I hate to do this but its the only feedback that I can get out of msiexec. What follows is a verbose log file recorded during the patch. I apologize for posting such a mess. The reason that I do it is that I get nothing logged when I simply use the error or warning options. Apparently msiexec thinks there are no errors or warnings. Thank you for any suggestions!
=== Verbose logging started: 8/27/03 13:28:19 Build type: SHIP UNICODE 2.00.2600.02 Calling process: C:\WINNT\System32\msiexec.exe ===
MSI © (76:42): Resetting cached policy values
MSI © (76:42): Machine policy value 'Debug' is 0
MSI © (76:42): ******* RunEngine:
******* Product: {579278CA-BAEF-41D1-A753-EC83659E4878}
******* Action:
******* CommandLine: **********
MSI © (76:42): Client-side and UI is none or basic: Running entire install on the server.
MSI © (76:42): Grabbed execution mutex.
MSI © (76:42): Incrementing counter to disable shutdown. Counter after increment: 0
MSI (s) (89:3C): Resetting cached policy values
MSI (s) (89:3C): Machine policy value 'Debug' is 0
MSI (s) (89:3C): ******* RunEngine:
******* Action:
MSI (s) (89:3C): Machine policy value 'DisableUserInstalls' is 0
MSI (s) (89:3C): End dialog not enabled
MSI (s) (89:3C): Original package ==> C:\WINNT\Installera8e.msi
MSI (s) (89:3C): Package we're running from ==> C:\WINNT\Installera8e.msi
MSI (s) (89:3C): APPCOMPAT: looking for appcompat database entry with ProductCode '{579278CA-BAEF-41D1-A753-EC83659E4878}'.
MSI (s) (89:3C): APPCOMPAT: no matching ProductCode found in database.
MSI (s) (89:3C): Machine policy value 'DisablePatch' is 0
MSI (s) (89:3C): Machine policy value 'AllowLockdownPatch' is 0
MSI (s) (89:3C): Opening database from URL: http://www.apexhomes.../OrderEntry.msp
MSI (s) (89:3C): Package path is a URL. Downloading package.
MSI (s) (89:3C): Note: 1: 2205 2: 3: Patch
MSI (s) (89:3C): Note: 1: 2228 2: 3: Patch 4: CREATE TABLE `Patch` ( `File_` CHAR(72) NOT NULL, `Sequence` INTEGER NOT NULL, `PatchSize` LONG NOT NULL, `Attributes` INTEGER NOT NULL, `Header` OBJECT, `StreamRef_` CHAR(72) PRIMARY KEY `File_`, `Sequence`
MSI (s) (89:3C): Note: 1: 2262 2: Patch 3: -2147287038
MSI (s) (89:3C): Opening existing patch 'C:\WINNT\Installerbc97.msp'.
MSI (s) (89:3C): Looking for storage transform: OrderEntry240ToCurrent
MSI (s) (89:3C): Validating transform 'OrderEntry240ToCurrent' with validation bits 0x922
MSI (s) (89:3C): Transform 'OrderEntry240ToCurrent' is valid.
MSI (s) (89:3C): Note: 1: 2205 2: 3: PatchPackage
MSI (s) (89:3C): Note: 1: 2262 2: _Tables 3: -2147287038
MSI (s) (89:3C): Note: 1: 2262 2: _Columns 3: -2147287038
MSI (s) (89:3C): TRANSFORM: 'PatchPackage' table is missing or empty. No pre-transform fixup necessary.
MSI (s) (89:3C): TRANSFORM: Applying regular transform to database.
MSI (s) (89:3C): Note: 1: 2262 2: _Validation 3: -2147287038
MSI (s) (89:3C): Note: 1: 2262 2: Condition 3: -2147287038
MSI (s) (89:3C): Note: 1: 2262 2: Directory 3: -2147287038
MSI (s) (89:3C): Note: 1: 2262 2: IsolatedComponent 3: -2147287038
MSI (s) (89:3C): Note: 1: 2262 2: Binary 3: -2147287038
MSI (s) (89:3C): Note: 1: 2262 2: Class 3: -2147287038
MSI (s) (89:3C): Note: 1: 2262 2: ProgId 3: -2147287038
MSI (s) (89:3C): Note: 1: 2262 2: Feature 3: -2147287038
MSI (s) (89:3C): Note: 1: 2262 2: CustomAction 3: -2147287038
MSI (s) (89:3C): Note: 1: 2262 2: InstallExecuteSequence 3: -2147287038
MSI (s) (89:3C): Note: 1: 2262 2: InstallUISequence 3: -2147287038
MSI (s) (89:3C): Note: 1: 2262 2: AdminExecuteSequence 3: -2147287038
MSI (s) (89:3C): Note: 1: 2262 2: AdminUISequence 3: -2147287038
MSI (s) (89:3C): Note: 1: 2262 2: SelfReg 3: -2147287038
MSI (s) (89:3C): Note: 1: 2262 2: Font 3: -2147287038
MSI (s) (89:3C): Note: 1: 2262 2: BindImage 3: -2147287038
MSI (s) (89:3C): Note: 1: 2262 2: AppSearch 3: -2147287038
MSI (s) (89:3C): Note: 1: 2262 2: AdvtExecuteSequence 3: -2147287038
MSI (s) (89:3C): Note: 1: 2262 2: AdvtUISequence 3: -2147287038
MSI (s) (89:3C): Note: 1: 2262 2: MIME 3: -2147287038
MSI (s) (89:3C): Note: 1: 2262 2: Extension 3: -2147287038
MSI (s) (89:3C): Note: 1: 2262 2: Verb 3: -2147287038
MSI (s) (89:3C): Note: 1: 2262 2: Registry 3: -2147287038
MSI (s) (89:3C): Note: 1: 2262 2: RemoveRegistry 3: -2147287038
MSI (s) (89:3C): Note: 1: 2262 2: ActionText 3: -2147287038
MSI (s) (89:3C): Note: 1: 2262 2: TypeLib 3: -2147287038
MSI (s) (89:3C): Note: 1: 2262 2: LaunchCondition 3: -2147287038
MSI (s) (89:3C): Note: 1: 2262 2: ModuleDependency 3: -2147287038
MSI (s) (89:3C): Note: 1: 2262 2: ModuleSignature 3: -2147287038
MSI (s) (89:3C): Note: 1: 2262 2: RegLocator 3: -2147287038
MSI (s) (89:3C): Note: 1: 2262 2: DrLocator 3: -2147287038
MSI (s) (89:3C): Note: 1: 2262 2: Signature 3: -2147287038
MSI (s) (89:3C): Note: 1: 2262 2: IniFile 3: -2147287038
MSI (s) (89:3C): Note: 1: 2262 2: ServiceInstall 3: -2147287038
MSI (s) (89:3C): Note: 1: 2262 2: Control 3: -2147287038
MSI (s) (89:3C): Note: 1: 2262 2: Dialog 3: -2147287038
MSI (s) (89:3C): Note: 1: 2262 2: ControlCondition 3: -2147287038
MSI (s) (89:3C): Note: 1: 2262 2: ControlEvent 3: -2147287038
MSI (s) (89:3C): Note: 1: 2262 2: Error 3: -2147287038
MSI (s) (89:3C): Note: 1: 2262 2: EventMapping 3: -2147287038
MSI (s) (89:3C): Note: 1: 2262 2: ListBox 3: -2147287038
MSI (s) (89:3C): Note: 1: 2262 2: RadioButton 3: -2147287038
MSI (s) (89:3C): Note: 1: 2262 2: TextStyle 3: -2147287038
MSI (s) (89:3C): Note: 1: 2262 2: UIText 3: -2147287038
MSI (s) (89:3C): Note: 1: 2262 2: _MsiPatchTransformView 3: -2147287038
MSI (s) (89:3C): Looking for storage transform: #OrderEntry240ToCurrent
MSI (s) (89:3C): Skipping transform validation for '#OrderEntry240ToCurrent'
MSI (s) (89:3C): Skipping validation for patch transform #OrderEntry240ToCurrent. Will apply because previous transform was valid
MSI (s) (89:3C): Transforming table Media.
MSI (s) (89:3C): Transforming table File.
MSI (s) (89:3C): TRANSFORM: The minimum 'Media.DiskId' value inserted by a patch transform is 100
MSI (s) (89:3C): TRANSFORM: The maximum 'Media.DiskId' value inserted by a patch transform is 99
MSI (s) (89:3C): TRANSFORM: The minimum 'File.Sequence' or 'Patch.Sequence' value inserted by a patch transform is 10000
MSI (s) (89:3C): TRANSFORM: The maximum 'File.Sequence' or 'Patch.Sequence' value inserted by a patch transform is 9999.
MSI (s) (89:3C): TRANSFORM: Applying special patch transform to database.
MSI (s) (89:3C): Note: 1: 2262 2: Component 3: -2147287038
MSI (s) (89:3C): Note: 1: 2262 2: Icon 3: -2147287038
MSI (s) (89:3C): Note: 1: 2262 2: Shortcut 3: -2147287038
MSI (s) (89:3C): Note: 1: 2262 2: FeatureComponents 3: -2147287038
MSI (s) (89:3C): Note: 1: 2262 2: ModuleComponents 3: -2147287038
MSI (s) (89:3C): Note: 1: 2262 2: ServiceControl 3: -2147287038
MSI (s) (89:3C): Note: 1: 2262 2: MsiPatchHeaders 3: -2147287038
MSI (s) (89:3C): Note: 1: 2262 2: PatchPackage 3: -2147287038
MSI (s) (89:3C): Transforming table PatchPackage.
MSI (s) (89:3C): TRANSFORM: Modifying 'File' and 'Patch' rows added by this patch transform to have appropriate 'Sequence' values. Offsetting values by 1775
MSI (s) (89:3C): TRANSFORM: Modifying 'PatchPackage' table row added by this patch transform to use 'Media_' value 100.
MSI (s) (89:3C): TRANSFORM: Modifying 'Media' table row added by this patch transform to use 'DiskId' value 100 and 'Source' values MSPSRCA3897BEE98C5416FA13982AFDA975D86.
MSI (s) (89:3C): Transforms are not secure.
MSI (s) (89:3C): Transforming table Property.
MSI (s) (89:3C): Command Line: REINSTALL=ALL REINSTALLMODE=omus PATCH=http://www.apexhomes.net/install/OrderEntry.msp CURRENTDIRECTORY=C:\WINNT\Profiles\Administrator\Desktop CLIENTUILEVEL=2 CLIENTPROCESSID=118 %HOMEPATH=\ %HOMEDRIVE=C: %HOMESHARE=
MSI (s) (89:3C): Product Code passed to Engine.Initialize: '{579278CA-BAEF-41D1-A753-EC83659E4878}'
MSI (s) (89:3C): Product Code from property table before transforms: '{579278CA-BAEF-41D1-A753-EC83659E4878}'
MSI (s) (89:3C): Product Code from property table after transforms: '{579278CA-BAEF-41D1-A753-EC83659E4878}'
MSI (s) (89:3C): Product registered: entering maintenance mode
MSI (s) (89:3C): Package name retrieved from configuration data: 'OrderEntry.msi'
MSI (s) (89:3C): Determined that existing product (either this product or the product being upgraded with a patch) is installed per-user.
MSI (s) (89:3C): Machine policy value 'DisableMsi' is 0
MSI (s) (89:3C): Machine policy value 'AlwaysInstallElevated' is 0
MSI (s) (89:3C): User policy value 'AlwaysInstallElevated' is 0
MSI (s) (89:3C): Product {579278CA-BAEF-41D1-A753-EC83659E4878} is not managed.
MSI (s) (89:3C): Running product '{579278CA-BAEF-41D1-A753-EC83659E4878}' with user privileges: It's not assigned.
MSI (s) (89:3C): TRANSFORMS property is now:
MSI (s) (89:3C): SHFOLDER::SHGetFolderPath returned: C:\WINNT\Profiles\Administrator\Application Data
MSI (s) (89:3C): SHFOLDER::SHGetFolderPath returned: C:\WINNT\Profiles\Administrator\Favorites
MSI (s) (89:3C): SHFOLDER::SHGetFolderPath returned: C:\WINNT\Profiles\Administrator\NetHood
MSI (s) (89:3C): SHFOLDER::SHGetFolderPath returned: C:\WINNT\Profiles\Administrator\Personal
MSI (s) (89:3C): SHFOLDER::SHGetFolderPath returned: C:\WINNT\Profiles\Administrator\PrintHood
MSI (s) (89:3C): SHFOLDER::SHGetFolderPath returned: C:\WINNT\Profiles\Administrator\Recent
MSI (s) (89:3C): SHFOLDER::SHGetFolderPath returned: C:\WINNT\Profiles\Administrator\SendTo
MSI (s) (89:3C): SHFOLDER::SHGetFolderPath returned: C:\WINNT\Profiles\Administrator\Templates
MSI (s) (89:3C): SHFOLDER::SHGetFolderPath returned: C:\WINNT\Profiles\All Users\Application Data
MSI (s) (89:3C): SHFOLDER::SHGetFolderPath returned: C:\WINNT\Profiles\Administrator\Local Settings\Application Data
MSI (s) (89:3C): SHFOLDER::SHGetFolderPath returned: C:\WINNT\Profiles\Administrator\Personal\My Pictures
MSI (s) (89:3C): SHFOLDER::SHGetFolderPath returned: C:\WINNT\Profiles\Administrator\Start Menu\Programs\Administrative Tools
MSI (s) (89:3C): SHFOLDER::SHGetFolderPath returned: C:\WINNT\Profiles\Administrator\Start Menu\Programs\Startup
MSI (s) (89:3C): SHFOLDER::SHGetFolderPath returned: C:\WINNT\Profiles\Administrator\Desktop
MSI (s) (89:3C): SHFOLDER::SHGetFolderPath returned: C:\WINNT\Profiles\All Users\Start Menu\Programs\Administrative Tools
MSI (s) (89:3C): SHFOLDER::SHGetFolderPath returned: C:\WINNT\Profiles\All Users\Start Menu\Programs\Startup
MSI (s) (89:3C): SHFOLDER::SHGetFolderPath returned: C:\WINNT\Profiles\All Users\Desktop
MSI (s) (89:3C): SHFOLDER::SHGetFolderPath returned: C:\WINNT\Fonts
MSI (s) (89:3C): Note: 1: 2898 2: MS Sans Serif 3: MS Sans Serif 4: 0 5: 16
MSI (s) (89:3C): MSCOREE not loaded loading copy from system32
MSI (s) (89:3C): Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\MS Setup (ACME)\User Info 3: 2
=== Logging started: 8/27/03 13:28:19 ===
MSI (s) (89:3C): Machine policy value 'DisableRollback' is 0
MSI (s) (89:3C): User policy value 'DisableRollback' is 0
MSI (s) (89:3C): Doing action: INSTALL
Action start 13:28:19: INSTALL.
MSI (s) (89:3C): Running ExecuteSequence
MSI (s) (89:3C): Doing action: DIR_CA_TARGETDIR
Action start 13:28:19: DIR_CA_TARGETDIR.
Action ended 13:28:19: DIR_CA_TARGETDIR. Return value 1.
MSI (s) (89:3C): Doing action: AppSearch
Action start 13:28:19: AppSearch.
Action ended 13:28:19: AppSearch. Return value 1.
MSI (s) (89:3C): Doing action: LaunchConditions
Action start 13:28:19: LaunchConditions.
Action ended 13:28:19: LaunchConditions. Return value 1.
MSI (s) (89:3C): Skipping action: CCPSearch (condition is false)
MSI (s) (89:3C): Skipping action: RMCCPSearch (condition is false)
MSI (s) (89:3C): Doing action: ValidateProductID
Action start 13:28:19: ValidateProductID.
Action ended 13:28:19: ValidateProductID. Return value 1.
MSI (s) (89:3C): Doing action: CostInitialize
Action start 13:28:19: CostInitialize.
MSI (s) (89:3C): Note: 1: 1336 2: 1005 3: D:\
MSI (s) (89:3C): Transforming table FeatureComponents.
MSI (s) (89:3C): Transforming table Component.
Action ended 13:28:19: CostInitialize. Return value 1.
MSI (s) (89:3C): Doing action: FileCost
Action start 13:28:19: FileCost.
MSI (s) (89:3C): Note: 1: 2205 2: 3: MsiAssembly
MSI (s) (89:3C): Transforming table Shortcut.
Action ended 13:28:19: FileCost. Return value 1.
MSI (s) (89:3C): Doing action: CostFinalize
Action start 13:28:19: CostFinalize.
MSI (s) (89:3C): Note: 1: 2228 2: 3: MsiAssembly 4: SELECT `MsiAssembly`.`Attributes`, `MsiAssembly`.`File_Application`, `MsiAssembly`.`File_Manifest`, `Component`.`KeyPath` FROM `MsiAssembly`, `Component` WHERE `MsiAssembly`.`Component_` = `Component
`.`Component` AND `MsiAssembly`.`Component_` = ?
MSI (s) (89:3C): Target path resolution complete. Dumping Directory table...
MSI (s) (89:3C): Note: target paths subject to change (via custom actions or browsing)
MSI (s) (89:3C): Dir (target): Key: _9EFD42F6C0E34C6E8DF640C1B457BA06 , Object: C:\
MSI (s) (89:3C): Dir (target): Key: _B8C5FBF3FA3948648740D4137183D316 , Object: C:\
MSI (s) (89:3C): Dir (target): Key: _D3A712EDD4D24EAAA03379EA6D11F8E1 , Object: C:\
MSI (s) (89:3C): Dir (target): Key: _A5BB6DC0A684469599361390231F952C , Object: C:\
MSI (s) (89:3C): Dir (target): Key: _D8F9674C570C4736B4D0A9C30B0E7531 , Object: C:\
MSI (s) (89:3C): Dir (target): Key: _9B587B80B28745FF876359F9E1427CCB , Object: C:\
MSI (s) (89:3C): Dir (target): Key: _A97758D8200B402C99C9C89A8E972736 , Object: C:\
MSI (s) (89:3C): Dir (target): Key: _74C0204B1B8F44399BAD9D09FDBF8C5E , Object: C:\
MSI (s) (89:3C): Dir (target): Key: _88105E4A574741858F3B8FA14D3AFA37 , Object: C:\
MSI (s) (89:3C): Dir (target): Key: _131691D8C9884376A53AA4080093723C , Object: C:\
MSI (s) (89:3C): Dir (target): Key: _CE01682B9D85483E8844A066F2C046B8 , Object: C:\
MSI (s) (89:3C): Dir (target): Key: _96C5CDDA24C9472DA945ECBBCBDA96F4 , Object: C:\
MSI (s) (89:3C): Dir (target): Key: TARGETDIR , Object: C:\Program Files\Apex Homes, Inc\Apex Order Entry\
MSI (s) (89:3C): Dir (target): Key: _7D9350E8DADA4C24B72E9081E67191C8 , Object: C:\Program Files\Apex Homes, Inc\Apex Order Entry\mysql\
MSI (s) (89:3C): Dir (target): Key: _5F0E9BEA862B4A67BEF9CC6710191368 , Object: C:\Program Files\Apex Homes, Inc\Apex Order Entry\mysql\share\
MSI (s) (89:3C): Dir (target): Key: _696B89988310429794252AB73E97F948 , Object: C:\Program Files\Apex Homes, Inc\Apex Order Entry\mysql\share\ukranian\
MSI (s) (89:3C): Dir (target): Key: _87842170D0A34175B86811DC37F6D738 , Object: C:\Program Files\Apex Homes, Inc\Apex Order Entry\mysql\share\swedish\
MSI (s) (89:3C): Dir (target): Key: _B0C8887C18E34D71A6F944EC1362E8A7 , Object: C:\Program Files\Apex Homes, Inc\Apex Order Entry\mysql\share\spanish\
MSI (s) (89:3C): Dir (target): Key: _87DC5CC738E84F61BE7449D71758B7C1 , Object: C:\Program Files\Apex Homes, Inc\Apex Order Entry\mysql\share\slovak\
MSI (s) (89:3C): Dir (target): Key: _DC2FDE53E164443CB88ACC93B74EF6AD , Object: C:\Program Files\Apex Homes, Inc\Apex Order Entry\mysql\share\russian\
MSI (s) (89:3C): Dir (target): Key: _D678A8B9E4874B78AA8D23B83B208395 , Object: C:\Program Files\Apex Homes, Inc\Apex Order Entry\mysql\share\romanian\
MSI (s) (89:3C): Dir (target): Key: _C42358F1BAC944D1B754905C8F2978B9 , Object: C:\Program Files\Apex Homes, Inc\Apex Order Entry\mysql\share\portuguese\
MSI (s) (89:3C): Dir (target): Key: _225293E0A9524745839FE6E6CF8DAC7E , Object: C:\Program Files\Apex Homes, Inc\Apex Order Entry\mysql\share\polish\
MSI (s) (89:3C): Dir (target): Key: _CFAC58293CD64928B1E9636F167828C2 , Object: C:\Program Files\Apex Homes, Inc\Apex Order Entry\mysql\share\norwegian-ny\
MSI (s) (89:3C): Dir (target): Key: _0ADF5594E9F8417C99BAA6E7E8A36A7B , Object: C:\Program Files\Apex Homes, Inc\Apex Order Entry\mysql\share\norwegian\
MSI (s) (89:3C): Dir (target): Key: _B1A701EC41204293BFDA914B13496B3A , Object: C:\Program Files\Apex Homes, Inc\Apex Order Entry\mysql\share\korean\
MSI (s) (89:3C): Dir (target): Key: _C5B277A0549F4A0AA9A8A37FC1B03BF9 , Object: C:\Program Files\Apex Homes, Inc\Apex Order Entry\mysql\share\japanese\
MSI (s) (89:3C): Dir (target): Key: _AFA256B406B843A6A5B3F5BD9D21F752 , Object: C:\Program Files\Apex Homes, Inc\Apex Order Entry\mysql\share\italian\
MSI (s) (89:3C): Dir (target): Key: _08EFBCFA90D9488F9646251E6F09A058 , Object: C:\Program Files\Apex Homes, Inc\Apex Order Entry\mysql\share\hungarian\
MSI (s) (89:3C): Dir (target): Key: _F9C64B2992FF4970AB299F1C4A2C508B , Object: C:\Program Files\Apex Homes, Inc\Apex Order Entry\mysql\share\greek\
MSI (s) (89:3C): Dir (target): Key: _F39AFB00EEB34121B412EE60366755CC , Object: C:\Program Files\Apex Homes, Inc\Apex Order Entry\mysql\share\german\
MSI (s) (89:3C): Dir (target): Key: _4B60D984BA5F42E69960E16EB81432B8 , Object: C:\Program Files\Apex Homes, Inc\Apex Order Entry\mysql\share\french\
MSI (s) (89:3C): Dir (target): Key: _3356A1BB12D24965B222B08BFC79E5B6 , Object: C:\Program Files\Apex Homes, Inc\Apex Order Entry\mysql\share\estonian\
MSI (s) (89:3C): Dir (target): Key: _541EF3D8D7EA46398B7537F756EC2F49 , Object: C:\Program Files\Apex Homes, Inc\Apex Order Entry\mysql\share\english\
MSI (s) (89:3C): Dir (target): Key: _90BE35FBCAB94C4B8117A88C8E8F7F60 , Object: C:\Program Files\Apex Homes, Inc\Apex Order Entry\mysql\share\dutch\
MSI (s) (89:3C): Dir (target): Key: _B52CD78F90334AC2B1A3BFDE2D5399DB , Object: C:\Program Files\Apex Homes, Inc\Apex Order Entry\mysql\share\danish\
MSI (s) (89:3C): Dir (target): Key: _2B1E5C0B521D4B88AE6134ADBD6C3EC6 , Object: C:\Program Files\Apex Homes, Inc\Apex Order Entry\mysql\share\czech\
MSI (s) (89:3C): Dir (target): Key: _76190DA448C2465E94F78D1CA7C464CF , Object: C:\Program Files\Apex Homes, Inc\Apex Order Entry\mysql\share\charsets\
MSI (s) (89:3C): Dir (target): Key: _AD99A9E2D567463BB899CD0C7A43E253 , Object: C:\Program Files\Apex Homes, Inc\Apex Order Entry\mysql\data\
MSI (s) (89:3C): Dir (target): Key: _DDC8AED2A3AE4776BB7F30045B5A1415 , Object: C:\Program Files\Apex Homes, Inc\Apex Order Entry\mysql\data\ApexOrderEntry\
MSI (s) (89:3C): Dir (target): Key: _E9F05A6ED7D64EE4A581676B57CDD037 , Object: C:\Program Files\Apex Homes, Inc\Apex Order Entry\mysql\data\mysql\
MSI (s) (89:3C): Dir (target): Key: _A0990564E8354FA1A4DB36394A547E4D , Object: C:\Program Files\Apex Homes, Inc\Apex Order Entry\mysql\bin\
MSI (s) (89:3C): Dir (target): Key: ProgramFilesFolder , Object: C:\Program Files\
MSI (s) (89:3C): Dir (target): Key: _202F7DE583C44E2CA8DF1787C6EFF900 , Object: C:\Program Files\Crystal Decisions\
MSI (s) (89:3C): Dir (target): Key: _6C5E4054E00949E1B5D0190097AC6127 , Object: C:\Program Files\Crystal Decisions\Report Designer Component\
MSI (s) (89:3C): Dir (target): Key: _F56FA20CF9AA490396473C4496CA4048 , Object: C:\Program Files\Crystal Decisions\
MSI (s) (89:3C): Dir (target): Key: _5576867888794E10A18081D170A4CEBC , Object: C:\Program Files\Crystal Decisions\Report Designer Component\
MSI (s) (89:3C): Dir (target): Key: _1B6F41D701E242919440249CC8E67A34 , Object: C:\Program Files\Crystal Decisions\
MSI (s) (89:3C): Dir (target): Key: _6045D3BCE9534445988EBA41DCC5A0BB , Object: C:\Program Files\Crystal Decisions\Report Designer Component\
MSI (s) (89:3C): Dir (target): Key: _E0F5036C9CC647E29CD77F7EB82856A4 , Object: C:\Program Files\Crystal Decisions\
MSI (s) (89:3C): Dir (target): Key: _FE5DF25EBAF2497AB0D6BE6A16832186 , Object: C:\Program Files\Crystal Decisions\Report Designer Component\
MSI (s) (89:3C): Dir (target): Key: WindowsFolder , Object: C:\WINNT\
MSI (s) (89:3C): Dir (target): Key: CommonFilesFolder , Object: C:\Program Files\Common Files\
MSI (s) (89:3C): Dir (target): Key: _41CC2D1054594F2D992F6C3E09D697E5 , Object: C:\Program Files\Common Files\Crystal Decisions\
MSI (s) (89:3C): Dir (target): Key: _37729CE7102E47A2B0E9242F0C377115 , Object: C:\Program Files\Common Files\Crystal Decisions.0\
MSI (s) (89:3C): Dir (target): Key: _8CB87B9BADB84429A757F2AF3407029A , Object: C:\Program Files\Common Files\Crystal Decisions.0\bin\
MSI (s) (89:3C): Dir (target): Key: _2C60D0A416DD48D0A017A1A830E54F6B , Object: C:\Program Files\Common Files\Crystal Decisions\
MSI (s) (89:3C): Dir (target): Key: _02810AE23C3E4DF492B331FB71298FE9 , Object: C:\Program Files\Common Files\Crystal Decisions.0\
MSI (s) (89:3C): Dir (target): Key: _00496F135E164A48A01015A25567E2B1 , Object: C:\Program Files\Common Files\Crystal Decisions.0\bin\
MSI (s) (89:3C): Dir (target): Key: _5D79A877AB5C4CBEA3AD275642FB4543 , Object: C:\Program Files\Common Files\Crystal Decisions\
MSI (s) (89:3C): Dir (target): Key: _ED154DB519914745B2CCEC3F2D456823 , Object: C:\Program Files\Common Files\Crystal Decisions.0\
MSI (s) (89:3C): Dir (target): Key: _CAE51E3762E74AB79210B70C3412658E , Object: C:\Program Files\Common Files\Crystal Decisions.0\bin\
MSI (s) (89:3C): Dir (target): Key: _DA1B5B2B1D7945DFA7E54A1825A29EF8 , Object: C:\Program Files\Common Files\Crystal Decisions\
MSI (s) (89:3C): Dir (target): Key: _DE586856DA5B445B89485F40152C7F82 , Object: C:\Program Files\Common Files\Crystal Decisions.0\
MSI (s) (89:3C): Dir (target): Key: _CD48D6899357412FBD3059E7C8CCB40A , Object: C:\Program Files\Common Files\Crystal Decisions.0\crystalreportviewers\
MSI (s) (89:3C): Dir (target): Key: _D3EC1B154F3441459A2EA0DC4E4122A7 , Object: C:\Program Files\Common Files\Crystal Decisions.0\crystalreportviewers\ActiveXViewer\
MSI (s) (89:3C): Dir (target): Key: _F9FD4FF9A23C40CDBEA69EB5DF147731 , Object: C:\Program Files\Common Files\Crystal Decisions\
MSI (s) (89:3C): Dir (target): Key: _2FD92AB2F2BD45F5AE6567E3166A3599 , Object: C:\Program Files\Common Files\Crystal Decisions.0\
MSI (s) (89:3C): Dir (target): Key: _31417D936F734041BDC1232BB9F6D48B , Object: C:\Program Files\Common Files\Crystal Decisions.0\bin\
MSI (s) (89:3C): Dir (target): Key: _A7EBABA94DED4E519E5FE4F0B5D5F993 , Object: C:\Program Files\Common Files\Crystal Decisions\
MSI (s) (89:3C): Dir (target): Key: _EB34774329174755AF08C372B163FCBA , Object: C:\Program Files\Common Files\Crystal Decisions.0\
MSI (s) (89:3C): Dir (target): Key: _B23DE7951E7B44A28ACFC3208C6579B7 , Object: C:\Program Files\Common Files\Crystal Decisions.0\crystalreportviewers\
MSI (s) (89:3C): Dir (target): Key: _04CFC48FF9594C1191D0596D3F42E709 , Object: C:\Program Files\Common Files\Crystal Decisions.0\crystalreportviewers\ActiveXViewer\
MSI (s) (89:3C): Dir (target): Key: _763EDE6493AF44FEBF7D039A57D52F40 , Object: C:\Program Files\Common Files\Crystal Decisions.0\bin\
MSI (s) (89:3C): Dir (target): Key: _78769FDBBD6E491CA3370F0D443A0567 , Object: C:\Program Files\Common Files\Crystal Decisions\
MSI (s) (89:3C): Dir (target): Key: _491C86C56031489EAB4B634FC3CF1DFE , Object: C:\Program Files\Common Files\Crystal Decisions.0\
MSI (s) (89:3C): Dir (target): Key: _7EFE37CB75F94237A59E2EF5EC19D042 , Object: C:\Program Files\Common Files\Crystal Decisions.0\bin\
MSI (s) (89:3C): Dir (target): Key: _BAF783405479450AB48CA3AD2951BB6A , Object: C:\Program Files\Common Files\Crystal Decisions\
MSI (s) (89:3C): Dir (target): Key: _07DD4DFBF65B483EAD94FA74EA4CA943 , Object: C:\Program Files\Common Files\Crystal Decisions.0\
MSI (s) (89:3C): Dir (target): Key: _10CFA30F222E402BAA48BCA49817B113 , Object: C:\Program Files\Common Files\Crystal Decisions.0\bin\
MSI (s) (89:3C): Dir (target): Key: StartMenuFolder , Object: C:\WINNT\Profiles\Administrator\Start Menu\
MSI (s) (89:3C): Dir (target): Key: _1926183E8DC84954AB8251BC33EC6C4B , Object: C:\WINNT\Profiles\Administrator\Start Menu\Programs\
MSI (s) (89:3C): Dir (target): Key: _AD0093F434254297BBAF30996AFBD0D0 , Object: C:\WINNT\Profiles\Administrator\Start Menu\Programs\Apex Order Entry\
MSI (s) (89:3C): Dir (target): Key: DesktopFolder , Object: C:\WINNT\Profiles\Administrator\Desktop\
MSI (s) (89:3C): Dir (target): Key: SystemFolder , Object: C:\WINNT\System32\
MSI (s) (89:3C): Dir (target): Key: Redist.51D569E0_8A28_11D2_B962_006097C4DE24 , Object: C:\WINNT\System32\
MSI (s) (89:3C): Dir (target): Key: MS.51D569E0_8A28_11D2_B962_006097C4DE24 , Object: C:\WINNT\System32\
MSI (s) (89:3C): Dir (target): Key: System.51D569E0_8A28_11D2_B962_006097C4DE24 , Object: C:\WINNT\System32\
MSI (s) (89:3C): Dir (target): Key: Redist.51D569E3_8A28_11D2_B962_006097C4DE24 , Object: C:\WINNT\System32\
MSI (s) (89:3C): Dir (target): Key: MS.51D569E3_8A28_11D2_B962_006097C4DE24 , Object: C:\WINNT\System32\
MSI (s) (89:3C): Dir (target): Key: System.51D569E3_8A28_11D2_B962_006097C4DE24 , Object: C:\WINNT\System32\
MSI (s) (89:3C): Dir (target): Key: Redist.3CE1F932_C090_11D2_977B_006097C4DE24 , Object: C:\WINNT\System32\
MSI (s) (89:3C): Dir (target): Key: MS.3CE1F932_C090_11D2_977B_006097C4DE24 , Object: C:\WINNT\System32\
MSI (s) (89:3C): Dir (target): Key: System.3CE1F932_C090_11D2_977B_006097C4DE24 , Object: C:\WINNT\System32\
MSI (s) (89:3C): Dir (target): Key: Redist.1E64E430_36E0_11D2_A794_0060089A724B , Object: C:\WINNT\System32\
MSI (s) (89:3C): Dir (target): Key: MS.1E64E430_36E0_11D2_A794_0060089A724B , Object: C:\WINNT\System32\
MSI (s) (89:3C): Dir (target): Key: System.1E64E430_36E0_11D2_A794_0060089A724B , Object: C:\WINNT\System32\
MSI (s) (89:3C): Dir (target): Key: Redist.7EBEDD3D_AA66_11D2_B980_006097C4DE24 , Object: C:\WINNT\System32\
MSI (s) (89:3C): Dir (target): Key: MS.7EBEDD3D_AA66_11D2_B980_006097C4DE24 , Object: C:\WINNT\System32\
MSI (s) (89:3C): Dir (target): Key: System.7EBEDD3D_AA66_11D2_B980_006097C4DE24 , Object: C:\WINNT\System32\
MSI (s) (89:3C): Dir (target): Key: Redist.7EBEDD6A_AA66_11D2_B980_006097C4DE24 , Object: C:\WINNT\System32\
MSI (s) (89:3C): Dir (target): Key: MS.7EBEDD6A_AA66_11D2_B980_006097C4DE24 , Object: C:\WINNT\System32\
MSI (s) (89:3C): Dir (target): Key: System.7EBEDD6A_AA66_11D2_B980_006097C4DE24 , Object: C:\WINNT\System32\
MSI (s) (89:3C): Dir (target): Key: Redist.51D569E2_8A28_11D2_B962_006097C4DE24 , Object: C:\WINNT\System32\
MSI (s) (89:3C): Dir (target): Key: MS.51D569E2_8A28_11D2_B962_006097C4DE24 , Object: C:\WINNT\System32\
MSI (s) (89:3C): Dir (target): Key: System.51D569E2_8A28_11D2_B962_006097C4DE24 , Object: C:\WINNT\System32\
MSI (s) (89:3C): Dir (target): Key: Redist.3207D1B0_80E5_11D2_B95D_006097C4DE24 , Object: C:\WINNT\System32\
MSI (s) (89:3C): Dir (target): Key: MS.3207D1B0_80E5_11D2_B95D_006097C4DE24 , Object: C:\WINNT\System32\
MSI (s) (89:3C): Dir (target): Key: System.3207D1B0_80E5_11D2_B95D_006097C4DE24 , Object: C:\WINNT\System32\
MSI (s) (89:3C): Dir (target): Key: Redist.7EBEDD68_AA66_11D2_B980_006097C4DE24 , Object: C:\WINNT\System32\
MSI (s) (89:3C): Dir (target): Key: MS.7EBEDD68_AA66_11D2_B980_006097C4DE24 , Object: C:\WINNT\System32\
MSI (s) (89:3C): Dir (target): Key: System.7EBEDD68_AA66_11D2_B980_006097C4DE24 , Object: C:\WINNT\System32\
MSI (s) (89:3C): Dir (target): Key: ANSI.7EBEDD68_AA66_11D2_B980_006097C4DE24 , Object: C:\WINNT\System32\
MSI (s) (89:3C): Dir (target): Key: Redist.8C0C59A0_7DC8_11D2_B95D_006097C4DE24 , Object: C:\WINNT\System32\
MSI (s) (89:3C): Dir (target): Key: MS.8C0C59A0_7DC8_11D2_B95D_006097C4DE24 , Object: C:\WINNT\System32\
MSI (s) (89:3C): Dir (target): Key: System.8C0C59A0_7DC8_11D2_B95D_006097C4DE24 , Object: C:\WINNT\System32\
MSI (s) (89:3C): Dir (target): Key: _5BAED41A1175488CA963880CC4D3C3CE , Object: C:\Program Files\Apex Homes, Inc\Apex Order Entry\msado15\
MSI (s) (89:3C): Dir (target): Key: _FE2068BFEB904AF6804F8CA58EFFBA79 , Object: C:\Program Files\Apex Homes, Inc\Apex Order Entry\msoutl9\
MSI (s) (89:3C): Dir (target): Key: _8BECB1719C8C41AABFA897589A5B24D1 , Object: C:\Program Files\Apex Homes, Inc\Apex Order Entry\crviewer9\
MSI (s) (89:3C): Dir (target): Key: _CBF0E67803C941B98F5027620F1ECE81 , Object: C:\Program Files\Apex Homes, Inc\Apex Order Entry\crviewer9\CRViewer9\
MSI (s) (89:3C): Dir (target): Key: _EE1CC3CA65584055AADED26B855640B9 , Object: C:\Program Files\Apex Homes, Inc\Apex Order Entry\craxddrt9\
MSI (s) (89:3C): Dir (target): Key: _771992D2E5E7481CA0B62AB82EE43A0B , Object: C:\Program Files\Apex Homes, Inc\Apex Order Entry\packages\
MSI (s) (89:3C): Dir (target): Key: _D4340459FCF544CB8F64376BEABA95AA , Object: C:\
Action ended 13:28:19: CostFinalize. Return value 1.
MSI (s) (89:3C): Skipping action: SetODBCFolders (condition is false)
MSI (s) (89:3C): Doing action: InstallValidate
Action start 13:28:19: InstallValidate.
MSI (s) (89:3C): Feature: _MainFeature; Installed: Advertise; Request: Reinstall; Action: Reinstall
MSI (s) (89:3C): Component: _D4340459FCF544CB8F64376BEABA95AA; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _347AFF34267543F18D47C633DF9CE496; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _53F02CB9AEA548E598A6A3FDC0612C12; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _1769A6B5F09D4FD8B650A4D6335CDEB1; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _0179EA0BAAAD41F4B7379518815A260F; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _39F049C14E8246F290DA97FE49A0F599; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _58391CD4B9CF427BB2BA9699CCD9F615; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _7662B1EF54AC42A9A3851BCB025BB43E; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _12D8F1B02A0A45BE9196A491231A49B1; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _D2788385648D4CF38DE16428A4515F88; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _7079B1B963B64C1687E1510A193EC559; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _EB224740C737498A8B677EE03D6706D7; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _DC319045464741B28DE1C1E03A56BD42; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _D7EAF3F04960432E91FF64AE3D341999; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _5BE220CD727641C7ABA0EBBC70DA6C95; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _C780DD04E88C46F4B52E1507BE492DD3; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _F128D1387D1D4593A0D6482E2903DDCD; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _17F88D58727D4E42AAC006E6417AED67; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _7E46FF1C0C124F7AA5C3BB1257A78202; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _C0E40B7AA8EA4830877DA537D2F7D8A5; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _562F07276C8B4212A0C62468E30F2EC5; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _56BCEF5B060945E0ADC5C2290B9BF0F1; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _597FCD27035641468F435E2B1E65A8CF; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _264A4C264C2A442EA1C48727A69AD228; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _4791380DF0644B3A8EF8816DEDD6BE2E; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _5561AD92828C4FD2951929BF325F3A66; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _765FE8DB7DE14E758F2528E7592F3051; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _BA55C5B201EB4577868918D3D57D2F36; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _A11BFF11EF404EBCA310D5FCF92C24AA; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _4A69B2EDDB31400FAB428DF241673A4C; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _C022A32B0A9148DDBE80D46D30B12FE9; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _923DFE90084042B98993FA1A98AE95C5; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _E3C8952DA91D470F8EA84C6CBC939FE0; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _5E3DDAB9A66445268FEF1EA099574C35; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _BA600252A72A49BCA6A4219E638899E6; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _F20FC407EBF04208891E1EFB3F333CF6; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _29C591478DB34B5AB52684D89BD57135; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _6354F13127BB4F69A7B5AF1D076F19AF; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _25FBCE87C9A542AFA036221D3286EF23; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _0E9E8B38BD2943F6916B24A30BC56252; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _7CEFD4DCDC214DA397BB8CB1B43E68F1; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _FC814FB8F7CA42CD80EBEAC7F160F927; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _423EA4A5D68846C585B1B97CEC7BF99E; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _4B0F98FDBAA140E1BC25AFC8D4D33536; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _A9DA060997404DB79B667E1563AFFCAB; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _13C4749B7D98477D81EFED7425CCB2C6; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _B37DB16BEA5645F296CDFE7FF7ED2CBF; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _ABA3DBC6FC71459386A98388084E01F1; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _857EA6C22C3F4E8C82557A05B41C0DEF; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _3B2E304879B942C0B4BAC16E5AF308CF; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _A15BECFF640D4821B56C64A90201D94D; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _60C407670BB9431AB45C700F21BDAD29; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _FE2738D7E63B471A923D48100206814E; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _D87E01D3279B40CCAEDC2517F1E84248; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _FCB276E7E5CF4E01808ADFDF7F1B7F42; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _D1C2EE5A67A44340B0191300E5C49E24; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _9A8B54CC92FF43ACBDEE68F937BF649D; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _55F96D6BEA514072883EBD27CD646959; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _58CD0C16F5274B5A81428AEB37396CF4; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _33E121B186714901A1DECD261416DFF5; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _6558B3AECAA347CC844235E84FC72E3A; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _A001225BB9A8436BB5DC9BBCC66B9C23; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _FE62DEA1CA264AAB874F28CB40C56FA4; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _4BA7F93D01A74C6EAD922A9A9DFC4762; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _1EFC8B53AEE748E7A8A5C4F22DB74F6A; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _5CD1BC08BA6D434E87DFEBC1F84F66A4; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _F3F2D1355B35450EA3734A05585B3000; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _4BB6B5E386294102BE6F36F0C265507D; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _BA39D65EB1074E17AFB4C04DD5B9A647; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _BB49A62F15C346608327E7DFE761B9BF; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _6C40F12D62BE404DB13BD489BCF5220D; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _C39DB70157BB4D50BB957136FCFDF0E7; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _2974980732B647A38BA99E2000D66F0F; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _26A7F18456BC4287ABF3EFE19D56D732; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _41388D20CA914D6A8F99BF0CF1B272C3; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _AB28F8E2355C4E5E9130050FD0E2AE2D; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _82229E0AF8564499892B5F276B97C99C; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _0A41B46CD96B4A2095F16B9AE1563353; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _8758D95C413F44C8A9CE4FBDDD8ED3F6; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _E7EA392FEE4749ED9104FB04EA0E65F0; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _36A9399CF53D42CBAA0261C1C6C1CC7D; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _5D407492745C4D0DBB40D94C3F15631A; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _6F01540C352F4116A0725F6B4E72BE1E; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _9F17353E80334B0B91EBE4957D551D0F; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _5E8B6E7C19B54CAEAB144AE7B294E1CC; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _4A57C0D2FAD242BD81F1C47EC25FCEDA; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _7FBE6325EF1D43E1AF853EAC5FDC9698; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _C6089CD419CD434A95E81FF226D428DB; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _5AC195F7C912402293208DC8F3B50955; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _5DA63E9BC9FB4E638106D7C0FEB4BF8A; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _52858D925D8742DD9D8CA01F38ED308D; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _912065ED06FE420FA62A99CF7E874C12; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _0188D9D65A9E4D99882575F39FD61127; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _7144ECF0AE8F4D968E3C75082DBFF077; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _FD262ACA69954CF18057165F7E3F5C42; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _F94BAA69937D46588533F0362F8F6701; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _256A5E61C096451E86BCC37B10432884; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _D2E9689B8D324E76A786AA9D44B0A061; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _AB3D51E148FE4536AA028F341536B1E7; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _3DFA2319B9D0455085BBB6D1973B391F; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _5DB662D115B84D138D88B297FCC6803C; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _92D02649AD6D41029ED9D92836FE5335; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _4A05071A708447069B4887BCD8ECDB34; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _EE5D49982FF949418D94828F34F40558; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _4A650183CD5840F9B1E130FC7FE7CBF3; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _496F817062D04CC6AD7F4FEC448181D5; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _57EEECCD2EDA49DB81EF84831605DF92; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _A71DC8B8DDD34BEBB619AD6AE73786EC; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _1C828C79BC1D4CEBB7E7255316620E92; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _F0DF0467511C42B587F8ACDACA2F923E; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _AC7E2A5A0BF64DF8BF36C978303D1EB4; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _BEF4FD1133664533AE084DAFF73F74CF; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _447165252B6240D3851121257DD2E987; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _55E4BC15E8CD47228A6CB7841ADA02D3; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _CDADCE4B6670456F902FDDCE897598D2; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _4F724BA95F7B41138897C7D6A061EF9E; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _2A304D473EDE456A84379E828810C898; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _E8CE4420898F46D8927F326E51842037; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _D306177FEA1D480092295DEA20D6FCA7; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _9D9CAC2AD6284EDAA9826D7DE130154D; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _8B409C754D1C4E24AF312063F68FA44C; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _DF2C0D3E9408461AB2AB335567E4846C; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _AA433554C75D43AC8660700D7EFFF5C6; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _05853DD8EE55473F91D6DC208D7B8F08; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _CC03064392BA4B98B3DC37350A5FB143; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _41E3E68AFFD54CA39F0D39613C5DFE17; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _9C148503709F42E1B907E0C7F7B7CFB2; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _96C5CDDA24C9472DA945ECBBCBDA96F4; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _FFE53E448C1E4E9AAAF2C6375C99ADEE; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _CE01682B9D85483E8844A066F2C046B8; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _7BBF1110F03B4341B5D60C5FA80E1469; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _69EA174F105040809DD0CF439903642C; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _2C9614F0778C4C3AB09B61CCF355048E; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _131691D8C9884376A53AA4080093723C; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _D6964B2DD646464DA574564F221FA0F6; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _B7E478B6CA7B4664BCEC809578DB5B41; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _DE27834DFB9D482AB2AE55027FAE6A03; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _DB89457D7AD94E1096284996B73B4DB4; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _46446CC10F98438E847D3DEB8ED0CE0D; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _4FADC3696E2B45B7B4B01CB342830B67; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _0B4F967730914EAEB9F2844F24D87BA5; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _D0ECF85C6B5A41C699674B91F3D300C8; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _04FAA81ED0BC410CA65A448C93ADBC09; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _AE04E8A7774F4292986F9702B4714015; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _51444E65EDF648C596F27ECDC6EF0F6A; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _2CF1414E3F49484DB8A53E7B9E2C458B; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _EA89AF87D3BF4CB9BCFA549962BFB45E; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _BE28DB56D7834B8A9BA61101C32526C0; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _D04D80E664C74DF784B4CA7428E79C92; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _1E1F080DD98D45D1A9F4A35345C33576; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _F39799C1E70F43D08D8BB402A51AC6F1; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _5E31F190AD1C4BB58ADBDDD4F7153FA8; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _B8B5CEEF0F954A1D8F0D75E7B7D42282; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _643D81966C4E4C578683497503B378B2; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _A13E328EC4544F93ADB7669B1E6C6A35; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _C0BD0C95EFB94ACDB56EF248F8F7437A; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _0518AEAF9AC149979A3C67E6E05B94DC; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _58CE034EADD448ABB20D0A819CB94E9E; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _6AB2737957724D42BD1B6D2486116F1A; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _3821C15CE16E49FB9E409738D6735CB6; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _A8720FD30C7C4A8CA6BD025D14835BD1; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _E3BBEEC3857B417B9B44E339B8C6030C; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _399ECD72161E44CD99324FDD10B823BD; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _287E5DE7BE0741F69C6D7E793D427862; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _062B4AB89E164C6298808640AF94F583; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _122721C66C9D4410BDDA422B1D9AEF9D; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _AE422FEBAF9C4F86B43EEE5BC44509BD; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _820A8BFFCDB24CC5A456794F62CA93D1; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _424C44D102BB4D29B09EB2D4D9DB5984; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _9A3B1C99D5FB415E83D464758D81F47B; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _3F9B6BF43A6E44768B813071C7AE31BB; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _CD2193DFEB5649DBA0F80002D646FF6B; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _012D76F76AB5468CB1024E29A22D1E22; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _030B59C8AFBA4AD0A571EEA62475316F; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _A095B9995E6C4969B1481F95602466FA; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _1DD58B9974374745A1EA1CD1F791A00D; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _42193C4CFAA8407EA245350C88CCCA0D; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _83B933B8EA7E4FCAA26015FBB21EE9C3; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _8F671165F2D7449A8E99CB1F93B1A9AF; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _7CA2DE8650494765A1B6164040A94621; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _4AF7447FEEC34F3D811B09DB9A9F9EF0; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _7034C5DC96224FA8993A2E0AD90B00EB; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _8C2D0A5F789248EBAF84A73F9355FF4C; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _027DC66F23EC4748B8AF83DFA7357625; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: Global_System_OLEPRO32.8C0C59A0_7DC8_11D2_B95D_006097C4DE24; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: Global_System_STDOLE.8C0C59A0_7DC8_11D2_B95D_006097C4DE24; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: Global_System_OLEAUT32.8C0C59A0_7DC8_11D2_B95D_006097C4DE24; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _88105E4A574741858F3B8FA14D3AFA37; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _3BEDCEF27146490A9CB2454463BACFCC; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _74C0204B1B8F44399BAD9D09FDBF8C5E; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _17EA06FFB6E8432ABB5049B2A1F449FE; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _A97758D8200B402C99C9C89A8E972736; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _CBEA8F1D53C949A89A07984858850103; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _9B587B80B28745FF876359F9E1427CCB; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _FEA7358A757E4AD78B5BBB2832EE091D; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _D8F9674C570C4736B4D0A9C30B0E7531; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _3CAAC907895F4BB280ECDCA62CBF63F5; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _A5BB6DC0A684469599361390231F952C; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _39A6C1D742A24B3C90E9643E6D3FB15F; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _D3A712EDD4D24EAAA03379EA6D11F8E1; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _3E325CBA7318433DB4B1C1DA7C636783; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _B8C5FBF3FA3948648740D4137183D316; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _CFB35C1CDFC541BEA05C63BA82A25EC3; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: Global_VC_ATLANSI.7EBEDD68_AA66_11D2_B980_006097C4DE24; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: Global_VC_ATLUnicode.7EBEDD68_AA66_11D2_B980_006097C4DE24; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: Global_Controls_COMCATDLL.3207D1B0_80E5_11D2_B95D_006097C4DE24; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: Global_VC_MFC42ANSICore.51D569E2_8A28_11D2_B962_006097C4DE24; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: Global_VC_MFC42UnicodeCore.7EBEDD6A_AA66_11D2_B980_006097C4DE24; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: Global_Vba_VBStandardFormat.7EBEDD3D_AA66_11D2_B980_006097C4DE24; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: Global_Vba_VbRuntime.1E64E430_36E0_11D2_A794_0060089A724B; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: Global_VC_IRT.3CE1F932_C090_11D2_977B_006097C4DE24; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: Global_VC_CPPRT60.51D569E3_8A28_11D2_B962_006097C4DE24; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: Global_VC_CRT.51D569E0_8A28_11D2_B962_006097C4DE24; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _9EFD42F6C0E34C6E8DF640C1B457BA06; Installed: Local; Request: Null; Action: Null
MSI (s) (89:3C): Component: _97037B69169445EA8F348DCB8721B015; Installed: Local;
******* Action:
******* Action:
Posted 27 August 2003 - 16:51
Posting a log is okay. Aattching it to the post would have been better. Also the file looks truncated.
Here are some suspect lines in the log:
This may be okay, unless you wanted it to be installed per-machine
This means: "There was an error creating a temporary file that is needed to complete this installation. Folder: D:\. System error code: 1005.
Where 1005 is something like "no valid file system found" (does drive D:\ exist? if it is a CD drive, is a CD in the drive?)
Some components have C:\ as their target directory. Maybe they don't have files in them so this may not be a problem. Using your regular install directory (TARGETDIR or INSTALLDIR)
Is that true? If the feature MainFeature should be installed locally, this line could indicate a violation of the update rules. As a result, all the components have "Action: Null"
Posted 27 August 2003 - 21:14
Stefan,
Thank you for delving into my mess! The problem persists after I took the following actions:
1) The per user thing was a mistake released with the original installation package (version 2.4.0). I forgot to put ALLUSERS=1 in the property table for that release. The patch package (version 2.4.2) has the ALLUSERS=1 in the properties table. For troubleshooting purposes, I have reinstalled the original package (version 2.4.0) using ALLUSERS=1 on the command line of msiexec to ensure there is no difference between the install level of the patch (version 2.4.2) and the original installation package (version 2.4.0). Once I did that the log changed to say that the installation was per machine, just like the patch.
2) There was indeed a D:\ drive. It was a non-recognizeable drive to NT b/c it is a partition where I store clean install images of several OS's using BOOTIT-NG. I removed that drive using disk administrator and the error message that you noted has disappeared from the log file.
3) All of those Dir(target) Keys are for unused SourceDir directories in the Directory table. I have several MSM packages that I authored using VSI and I think that they accumulated from those packages.
4) Um, gee, I didn't think that it was installed Advertised. That sure could explain a lot! I can see the files physically installed on the HD though.
That really sounds like the problem. I am going to see if I can find a way to explicitly set the install state of _MainFeature through the command line or whatever.
Also, do you know of a way that I can monitor the install state of _MainFeature before I apply the patch?
That interpretation of the log is mighty impressive! Is there a reference that I could use that explains the output of the log in the WI SDK, msdn or elsewhere?
Thank you very VERY much!
Posted 27 August 2003 - 21:50
More interesting facts:
One of the msp's that worked is the version 2.4.1 patch. I tried this one out on the exact same version 2.4.0 installation with a verbose log. The line that you meantioned said that _MainFeature was installed Local. Then, I tried the 2.4.2 patch after the 2.4.1 patch. The line you meantioned said that _MainFeature was installed Advertised!
I tried recreating the patch without the ListOfPatchGUIDsToReplace since my previous, successful patches did not have a ListOfPatchGUIDsToReplace. That had no effect on the problem.
I must be violating some sort of patch rule that is causing this non-sensical problem. Perhaps by my numbers in the MediaDiskID or FileSequenceStart fields of the ImageFamilies table are off. I will check into that.
Posted 28 August 2003 - 11:42
My guess would be that you have done one of the following:
- changed a component GUID
- changed the key path of a component (selected another file as key, or changed the key to be a registry entry, ...)
- moved a component from one feature to another
- moved existing feature in the feature tree
- changed the destination directory of a component
- removed a file from a component and that component is shared across features
Any of the above that's related to components might as well not have happened in your main project but in a merge module you include.
Also the log seems to indicate a problem with your file and media sequence numbers.
The MSI SDK includes a log file analyzer that also includes some documentation.
Posted 29 August 2003 - 20:08
I've only got one feature so that knocks out the following:
I did compare my feature table between the two versions and there are no changes to the GUIDs or key paths but...
How about deleting components? Is that allowed?
The way that VSI handles files, file=component and I did remove several files that dropped their corresponding components. I looked at your bit about rules for patches and I wonder if that might fall under the following category:
- If you remove a file or registry key from a component, you must populate the RemoveFile or RemoveRegistry table respectively to delete the orphaned resource.
Well, I didn't delete the file from the component but I did delete the whole component and the file! The only problem with populating the RemoveFile table is that I can't have the files removed. They are removed as part of a database upgrade process that will be executed the next time that the app is run. If those files get removed before the database is upgraded, the MySQL db will not be able upgrade those files that are part of the db.
I may have gotten myself into this situation by using WI to distribute data. I've not found what feels like the right way to distribute data with an app yet.
Is there any way to delete components and still patch or do I need to shift to an upgrade?
Posted 29 August 2003 - 21:51
[deleted wrong and misleading statement]
You only need to add an entry to the RemoveFile table if you don't want to leave these files behind, as they will not be removed during uninstall.
Posted 29 August 2003 - 21:58
As oh so clearly stated in the WI SDK:
The product code must be changed if an any of the following are true for the update:
Its a requirement that it be possible to have coexisting installations of the original and updated products on the same system.
The name of the .msi file has been changed.
The component code of an existing component has changed.
A component has been added or removed from an existing feature.
An existing feature has been made into a child of an existing feature.
An existing child feature has been removed from its parent feature.
Looks like I need to do a major update. Thank you for your feedback Stefan, your advice has been instrumental in helping me think through this problem!
