I'm trying to re-install a software created by Installshield Dev Studio 9, and when i try to reinstall it without removingthe previous software i'm getting an error code "Error -1603, Fatal Error During installation, Consult Windows installer help(msi.chm), and when i click ok i again get a msg withthe following error code "error 1316, a network error occured while attempting the read from the file (path of the file\filename.msi), can u pls tel me how to solve this issue.. I have tried in ll the pc's it is giving methe same error. it is not letting me to reinstall a software over an existing software. I wil really very thankful to you, Its really very urgent kindly help me pls.
Thanks & Regards
Syed Tausif Akram
error 1603 fatal error during installation
syedtausif
, Nov 03 2009 06:20
6 replies to this topic
Posted 03 November 2009 - 07:11
QUOTE (syedtausif @ 2009-11-03 05:20) |
Hi, I'm trying to re-install a software created by Installshield Dev Studio 9, and when i try to reinstall it without removingthe previous software i'm getting an error code "Error -1603, Fatal Error During installation, Consult Windows installer help(msi.chm), and when i click ok i again get a msg withthe following error code "error 1316, a network error occured while attempting the read from the file (path of the file\filename.msi), can u pls tel me how to solve this issue.. I have tried in ll the pc's it is giving methe same error. it is not letting me to reinstall a software over an existing software. I wil really very thankful to you, Its really very urgent kindly help me pls. Thanks & Regards Syed Tausif Akram |
Hi Tauseef,
Did you checked the documentation for -1603 and 1316?
Posted 03 November 2009 - 09:17
QUOTE |
THIS SECTION IS NOT FOR MSI (WINDOWS INSTALLER) PROJECTS, not even for "InstallScript MSI" |
Moving question to the forum for MSI projects
Posted 09 November 2009 - 06:02
Re-install a software with out uninstalling the previous version of the software may hampers the installation until and unless the later is an Minor/Major upgrade over previous. Try to remove the existing s/w via control panel and install the latest software. Ensure that all the registry entries should be deleted before you are installing the latest software.
Registry entries:
Might be from shared dlls 1. HKLM\SOFTWARE\MICROSOFT\WINDOWS\CURRENTVRERSION\SHAREDDLLS
2. Product GUID from UNINSTALL folder of registry
3. If presents , the .exe path from APPPATH folder from registry
Proper uninstall and install will definately works at all time with out any issue
Registry entries:
Posted 01 December 2009 - 16:01
Is there any other way to do it? because i want to overwrite the existing software with a new one without uninstalling it, when i do so i'm getting an "error 1603- fatal error during installation, a network error occurred", when i searched for help i got a utility called 'Windows Cleanup Utility' using which i have to delete the entry from windows installed in the pc and then i'm able to overwrite the software, but can anuone tel me a way as to how to install it without removing the current version from the pc? Is there any other way or any property i have to set in Installshield 9?
Kindly help me out with this issue...
thanks in Advance
Regards,
Syed Tausif Akram.
thanks in Advance
Regards,
Syed Tausif Akram.
Posted 02 December 2009 - 04:33
You can try for Minor upgrade which inturn overwrites the existing version
Posted 03 December 2009 - 11:22
How to do the minor update? Is there any way or any property that i can set in Installshield?!!! After building the software package in installshield i install it above an existing one but it throws me the error 1603 even if the user has Administrator rights to the login!!!!
Thanks in Advance..
Regards,
Syed Tausif Akram.
Thanks in Advance..
Regards,
Syed Tausif Akram.
