Is it possible to change a Feature's Install Level using a Public property? I created a dialog that has 2 install options ('A' and 'B') using check boxes and associated public properties with them ('CHECK_BOX_A' and 'CHECK_BOX_B'). I then created 2 Features ('FeatureOne' and 'FeatureTwo') and set their Install Levels to '200'. I want to be able to change their Install Level to '1' if their corresponding check box is selected (selecting 'A' gets 'FeatureOne' and 'B' gets 'FeatureTwo'). I'm using the Condition syntax of 'CHECK_BOX_A=1' to set its Install Level to '1'. What's strange is that the same Condition syntax works at the Component level but not at the Feature level. Any help will be appreciated...
Note: It's an InstallShield 11.5 Basic MSI project.
Changing Feature Install Level w/ Public Property
snively
, Jan 10 2006 01:56
