Dialog changes don't get saved.
Posted 18 April 2001 - 20:51
Any suggestions???
Posted 19 April 2001 - 01:18
I had the same problem when I was modifying the various controls and changing the string ID names - they sometimes did not get hooked up to the controls correctly and were basically ignored. Sometimes in fact the dialog failed to display on the next opening because it could not find the strings. I reported this to IS and they are working on it.
In the meantime, I became *very" careful modifying the string IDs, doing one/two at a timebefore saving. Note that I could tell I had a problem when hitting the Save icon did not disable the icon, and does not no matter how many times you hit it. At that point you are screwed, and have lost the work since the last save.
I also exported the dialog often for those times it disappeared.
Hope this helps.
Cheers,
Graham
