Heres a real tricky one:
You can DISABLE the cancel button while using the command:
msiexec.exe /X {productID} /qb+!
BUT when you try it through Add/Remove programs, the cancel button isnt disabled.... ONLY through the command line.
I tried modifying the registry under the values QuietInstallString, ModifyPath, and Uninstall String. These values are located in the HKLM/Software/Microsoft/Windows/Uninstall and Install locations. I included this SAME line, but no luck.
so the question is - How can you disable the CANCEL button during Add/Remove Programs option like the one above using this /qb+!?
Good luck!
chris
Here's a REAL tricky one!
channel0
, Jul 15 2002 21:23
