Hello.
I have an InstallScript project, named an_is. The product name is set to an_is, respectively.
But I need to set another name of the product, depending upon different circumstances.
How (and where) would I do that, so that new product name will appear from the beginning (window "an_is - InstallShield Wizard").
How to set product name in code?
bezlepkin
, Oct 25 2005 08:50
Posted 25 October 2005 - 15:32
The SdProductName function allows you to change the product name in some of the Dialogs. From the help file: The SdProductName function makes your product name available to all instances of the %P place holder. The %P place holder is found in static text fields in some Sd dialog boxes.
However, I don't believe this will change the name that is shown in the very first dialog that has the progress bar as the install is unzipping its files.
