I have a merge module that has several components. Under a particular component, under the Files category, there are 5 sub folders, Active, Crystal, Images, Reports and ReportTemplates. All sub folders have modules in them, except for Reports. When I do an installation (that does include this merge module), the main folder is LSRF, and under that folder I see Active, Crystal, Images and ReportTemplates, but not Reports.
I see other components that also have sub folders under the File category, which also have no modules in them, but those sub folders are created when an install is done.
Any hints as to why this 1 sub folder is not being created??
I'm using IS 11, Basic MSI's.
Thanks, Tim
Sub folder not getting created at install
thil43
, Apr 15 2008 21:11
Posted 16 April 2008 - 13:24
You might want to put any empty folders you need to have created in the CreateFolder table.
Kathy Morey
Synergy Software Engineer
kmorey@profitstars.com
Posted 16 April 2008 - 21:55
Thanks Kathy. I found out that the entry in the CreateFolder table was not right. Seems ok now - thanks very much for the help!
