Hi All,
I hope someone can help.
We have a customer trying to run our installation, which sets up/configures a web site. They are attempting to run in on 64 bit Windows Server 2008. They get a fatal error with no real error number or good description so I walked them through logging the install. I tried to upload the file as .txt and .log but was unable to so a snippet of the log with 'fatal' references is displayed below.
Property(S): WISEVIRTUALDIRECTORY7_HOMEDIR = C:\inetpub\wwwroot\Adept\
Property(S): WISEVIRTUALDIRECTORY7_INSTTYPE = VIRDIR
Property(S): SourceDir = E:\downloads\NewAdept\Adept Explorer 8.1.1\AutoPlay\
Property(S): SourcedirProduct = {7206BF5A-5261-4B95-B071-2BCD5BF576F7}
Property(S): ProductToBeRegistered = 1
MSI (s) (88:C4) [13:28:40:952]: MainEngineThread is returning 1603
MSI (s) (88:C8) [13:28:40:952]: RESTART MANAGER: Session closed.
MSI (s) (88:C8) [13:28:40:952]: No System Restore sequence number for this installation.
MSI (s) (88:C8) [13:28:40:968]: User policy value 'DisableRollback' is 0
MSI (s) (88:C8) [13:28:40:968]: Machine policy value 'DisableRollback' is 0
MSI (s) (88:C8) [13:28:40:968]: Incrementing counter to disable shutdown. Counter after increment: 0
MSI (s) (88:C8) [13:28:40:968]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installer\Rollback\Scripts 3: 2
MSI (s) (88:C8) [13:28:40:968]: Decrementing counter to disable shutdown. If counter >= 0, shutdown will be denied. Counter after decrement: -1
MSI (s) (88:C8) [13:28:40:968]: Restoring environment variables
MSI (s) (88:C8) [13:28:40:968]: Destroying RemoteAPI object.
MSI (s) (88:90) [13:28:40:968]: Custom Action Manager thread ending.
MSI © (BC:B4) [13:28:40:984]: Back from server. Return value: 1603
MSI © (BC:B4) [13:28:40:984]: Decrementing counter to disable shutdown. If counter >= 0, shutdown will be denied. Counter after decrement: -1
MSI © (BC:B4) [13:28:40:984]: PROPERTY CHANGE: Deleting SECONDSEQUENCE property. Its current value is '1'.
Action ended 13:28:40: ExecuteAction. Return value 3.
MSI © (BC:B4) [13:28:40:984]: Doing action: Fatal_Error
Action 13:28:40: Fatal_Error.
Action start 13:28:40: Fatal_Error.
MSI © (BC:B4) [13:28:40:984]: Note: 1: 2235 2: 3: ExtendedType 4: SELECT `Action`,`Type`,`Source`,`Target`, NULL, `ExtendedType` FROM `CustomAction` WHERE `Action` = 'Fatal_Error'
Action 13:28:40: Fatal_Error. Dialog created
MSI © (BC:0C) [13:28:44:609]: Doing action: WiseCleanup
Action 13:28:44: WiseCleanup.
Action start 13:28:44: WiseCleanup.
MSI © (BC:0C) [13:28:44:609]: Note: 1: 2235 2: 3: ExtendedType 4: SELECT `Action`,`Type`,`Source`,`Target`, NULL, `ExtendedType` FROM `CustomAction` WHERE `Action` = 'WiseCleanup'
MSI © (BC:C0) [13:28:44:624]: Invoking remote custom action. DLL: C:\Users\ADMINI~1.HOM\AppData\Local\Temp\2\MSI1DDB.tmp, Entrypoint: Cleanup
Action ended 13:28:44: WiseCleanup. Return value 1.
Action ended 13:28:44: Fatal_Error. Return value 2.
Action ended 13:28:44: INSTALL. Return value 3.
MSI © (BC:B4) [13:28:44:671]: Destroying RemoteAPI object.
MSI © (BC:40) [13:28:44:687]: Custom Action Manager thread ending.
Property©: Description = Synergis Adept Web Application
Property©: Help = C:\inetpub\wwwroot\Adept7\Help\
Property©: DiskPrompt = [ProductName] [1]
Property©: UpgradeCode = {11FCFF24-4327-44A7-BD91-A8FF8EF4374E}
Property©: InstallMode = Complete
Property©: ROOTDRIVE = E:\
Property©: IISVERSION = 700
If anyone could take a look at the log and let me know what they think I would greatly appreciate it. If you need to see the full log, let me now what format I can upload with.
Hope to hear from someone soon!
Fatal Error I Can't Figure Out...
Superfreak3
, Nov 16 2009 04:55
6 replies to this topic
Posted 16 November 2009 - 09:29
With any MSI log, the part to post is the dozen or so lines above and below the first occurence of the text "Return value 3.".
Use the CODE tag to enclose any lengthy text like this and it will appear in a scrollable textarea, making the post much easier to read.
Posted 16 November 2009 - 14:59
Oh, sorry about that. The fatal error stuff is down at the bottom of the code with more information provided above.
Even surrounded in the CODE tag it doesn't appear scrollable...
| Property(S): LocalAppDataFolder = C:\Users\administrator.HOME-SHIELD\AppData\Local\ Property(S): tc = C:\Program Files (x86)\jVue\bin\jetty\etc\ Property(S): StartMenuFolder = C:\Users\administrator.HOME-SHIELD\AppData\Roaming\Microsoft\Windows\Start Menu\ Property(S): app_data = E:\Adept7\app_data\ Property(S): Profiles = C:\Program Files (x86)\jVue\bin\Profiles\ Property(S): app_code = E:\Adept7\app_code\ Property(S): App_Data = C:\inetpub\wwwroot\Adept7\App_Data\ Property(S): Adept_Explorer = C:\Users\administrator.HOME-SHIELD\AppData\Roaming\Synergis\Adept Explorer\ Property(S): INSTALLDIR3 = C:\Program Files (x86)\Synergis\ Property(S): Adept_Explorer4 = C:\Program Files (x86)\Synergis\Adept Explorer\ Property(S): TemplateFolder = C:\Users\administrator.HOME-SHIELD\AppData\Roaming\Microsoft\Windows\Templates\ Property(S): fonts = C:\Program Files (x86)\jVue\bin\fonts\ Property(S): servlets = C:\Program Files (x86)\jVue\bin\jetty\servlets\ Property(S): lib = C:\Program Files (x86)\jVue\bin\jetty\lib\ Property(S): Viewer = C:\Program Files (x86)\Synergis\Adept Explorer\Viewer\ Property(S): help = C:\inetpub\wwwroot\Adept\help\ Property(S): bin7 = C:\inetpub\wwwroot\Adept\bin\ Property(S): junk = C:\inetpub\wwwroot\Adept7\junk\ Property(S): Client_Files = C:\Program Files (x86)\Synergis\Adept Explorer\Client Files\ Property(S): VersionNT = 600 Property(S): USERNAME = Troy Olson Property(S): COMPANYNAME = HOMESHIELD Property(S): WISEVIRTUALDIRECTORY7_VIRDIR_NAME_CHILD = Adept Property(S): WISEWEBSITES1_SITE_DESC_LIST = Adept Property(S): FTPNAME1 = AdeptFTP Property(S): ADEPT_FOLDER = Adept Property(S): AVDIR = C:\Program Files (x86) Property(S): ARPINSTALLLOCATION = C:\inetpub\wwwroot\Adept\ Property(S): UserSID = S-1-5-21-1220945662-1897051121-725345543-500 Property(S): LogonUser = administrator Property(S): AdminUser = 1 Property(S): VirtualMemory = 21247 Property(S): PhysicalMemory = 11199 Property(S): Intel = 15 Property(S): Msix64 = 15 Property(S): MsiAMD64 = 15 Property(S): ShellAdvtSupport = 1 Property(S): OLEAdvtSupport = 1 Property(S): GPTSupport = 1 Property(S): CommonFiles64Folder = C:\Program Files\Common Files\ Property(S): ProgramFiles64Folder = C:\Program Files\ Property(S): RemoteAdminTS = 1 Property(S): System64Folder = C:\Windows\system32\ Property(S): WindowsVolume = C:\ Property(S): MsiNTSuiteEnterprise = 1 Property(S): MsiNTProductType = 3 Property(S): ServicePackLevelMinor = 0 Property(S): ServicePackLevel = 2 Property(S): WindowsBuild = 6002 Property(S): VersionNT64 = 600 Property(S): VersionMsi = 4.05 Property(S): ADDLOCAL = Complete Property(S): WISEWEBSITES1_VD_EXISTING_SITE = Adept Property(S): WISEVIRTUALDIRECTORY7_VIRDIR_NAME_SAVE = Adept Property(S): WISEWEBSITES1_SITE_LOCATION_SAVE = VirtualDirectory Property(S): WISEWEBSITES1_WS_LOCATION = VirtualDirectory Property(S): WISEWEBSITES1_ATTR_INDEX = 1 Property(S): WISEWEBSITES1_ATTR_LOG_VISITS = 1 Property(S): WISEWEBSITES1_ATTR_READ = 1 Property(S): WISEWEBSITES1_SSL_PORT = 0 Property(S): WISEWEBSITES1_TCP_PORT = 80 Property(S): WISEWEBSITES1_SITE_DESC = Adept Property(S): WISEVIRTUALDIRECTORY7_VIRDIR_NAME = Adept Property(S): WISEVIRTUALDIRECTORY9_VIRDIR_NAME_CHILD = Adept/help Property(S): WISEVIRTUALDIRECTORY9_VIRDIR_NAME = Adept/help Property(S): WISEVIRTUALDIRECTORY8_VIRDIR_NAME_CHILD = Adept/bin Property(S): WISEVIRTUALDIRECTORY8_VIRDIR_NAME = Adept/bin Property(S): WISEWEBCOUNT = 0 Property(S): CURRENTDIRECTORY = C:\Windows\system32 Property(S): CLIENTUILEVEL = 0 Property(S): CLIENTPROCESSID = 6076 Property(S): VersionDatabase = 200 Property(S): ACTION = INSTALL Property(S): EXECUTEACTION = INSTALL Property(S): IISVERSION = 700 Property(S): SECONDSEQUENCE = 1 Property(S): ROOTDRIVE = E:\ Property(S): PackagecodeChanging = 1 Property(S): ProductState = -1 Property(S): PackageCode = {5140EFA0-8A30-4E49-99F1-0D1B848A6A44} Property(S): MsiLogFileLocation = c:\temp\adept.log Property(S): CostingComplete = 1 Property(S): OutOfDiskSpace = 0 Property(S): OutOfNoRbDiskSpace = 0 Property(S): PrimaryVolumeSpaceAvailable = 118168800 Property(S): PrimaryVolumeSpaceRequired = 42735 Property(S): PrimaryVolumeSpaceRemaining = 118126065 Property(S): PrimaryVolumePath = C: Property(S): WISEVIRTUALDIRECTORY8_BEGINURL = http://localhost/Adept/bin/ Property(S): WISEVIRTUALDIRECTORY8_URL = http://localhost/Adept/bin Property(S): WISEVIRTUALDIRECTORY8_HOMEDIR = C:\inetpub\wwwroot\Adept\bin\ Property(S): WISEVIRTUALDIRECTORY9_BEGINURL = http://localhost/Adept/help/ Property(S): WISEVIRTUALDIRECTORY9_URL = http://localhost/Adept/help Property(S): WISEVIRTUALDIRECTORY9_HOMEDIR = C:\inetpub\wwwroot\Adept\help\ Property(S): WISEVIRTUALDIRECTORY7_BEGINURL = http://localhost/Adept/ Property(S): WISEVIRTUALDIRECTORY7_URL = http://localhost/Adept Property(S): WISEVIRTUALDIRECTORY7_HOMEDIR = C:\inetpub\wwwroot\Adept\ Property(S): WISEVIRTUALDIRECTORY7_INSTTYPE = VIRDIR Property(S): SourceDir = E:\downloads\NewAdept\Adept Explorer 8.1.1\AutoPlay\ Property(S): SourcedirProduct = {7206BF5A-5261-4B95-B071-2BCD5BF576F7} Property(S): ProductToBeRegistered = 1 MSI (s) (88:C4) [13:28:40:952]: MainEngineThread is returning 1603 MSI (s) (88:C8) [13:28:40:952]: RESTART MANAGER: Session closed. MSI (s) (88:C8) [13:28:40:952]: No System Restore sequence number for this installation. MSI (s) (88:C8) [13:28:40:968]: User policy value 'DisableRollback' is 0 MSI (s) (88:C8) [13:28:40:968]: Machine policy value 'DisableRollback' is 0 MSI (s) (88:C8) [13:28:40:968]: Incrementing counter to disable shutdown. Counter after increment: 0 MSI (s) (88:C8) [13:28:40:968]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installer\Rollback\Scripts 3: 2 MSI (s) (88:C8) [13:28:40:968]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installer\Rollback\Scripts 3: 2 MSI (s) (88:C8) [13:28:40:968]: Decrementing counter to disable shutdown. If counter >= 0, shutdown will be denied. Counter after decrement: -1 MSI (s) (88:C8) [13:28:40:968]: Restoring environment variables MSI (s) (88:C8) [13:28:40:968]: Destroying RemoteAPI object. MSI (s) (88:90) [13:28:40:968]: Custom Action Manager thread ending. MSI (c) (BC:B4) [13:28:40:984]: Back from server. Return value: 1603 MSI (c) (BC:B4) [13:28:40:984]: Decrementing counter to disable shutdown. If counter >= 0, shutdown will be denied. Counter after decrement: -1 MSI (c) (BC:B4) [13:28:40:984]: PROPERTY CHANGE: Deleting SECONDSEQUENCE property. Its current value is '1'. Action ended 13:28:40: ExecuteAction. Return value 3. MSI (c) (BC:B4) [13:28:40:984]: Doing action: Fatal_Error Action 13:28:40: Fatal_Error. Action start 13:28:40: Fatal_Error. MSI (c) (BC:B4) [13:28:40:984]: Note: 1: 2235 2: 3: ExtendedType 4: SELECT `Action`,`Type`,`Source`,`Target`, NULL, `ExtendedType` FROM `CustomAction` WHERE `Action` = 'Fatal_Error' Action 13:28:40: Fatal_Error. Dialog created MSI (c) (BC:0C) [13:28:44:609]: Doing action: WiseCleanup Action 13:28:44: WiseCleanup. Action start 13:28:44: WiseCleanup. MSI (c) (BC:0C) [13:28:44:609]: Note: 1: 2235 2: 3: ExtendedType 4: SELECT `Action`,`Type`,`Source`,`Target`, NULL, `ExtendedType` FROM `CustomAction` WHERE `Action` = 'WiseCleanup' MSI (c) (BC:C0) [13:28:44:624]: Invoking remote custom action. DLL: C:\Users\ADMINI~1.HOM\AppData\Local\Temp\2\MSI1DDB.tmp, Entrypoint: Cleanup Action ended 13:28:44: WiseCleanup. Return value 1. Action ended 13:28:44: Fatal_Error. Return value 2. Action ended 13:28:44: INSTALL. Return value 3. MSI (c) (BC:B4) [13:28:44:671]: Destroying RemoteAPI object. MSI (c) (BC:40) [13:28:44:687]: Custom Action Manager thread ending. Property(C): Description = Synergis Adept Web Application Property(C): Help = C:\inetpub\wwwroot\Adept7\Help\ Property(C): DiskPrompt = [ProductName] [1] Property(C): UpgradeCode = {11FCFF24-4327-44A7-BD91-A8FF8EF4374E} Property(C): InstallMode = Complete Property(C): ROOTDRIVE = E:\ Property(C): IISVERSION = 700 Property(C): EXECUTEACTION = INSTALL Property(C): ACTION = INSTALL Property(C): UILevel = 5 Property(C): ProductCode = {7206BF5A-5261-4B95-B071-2BCD5BF576F7} Property(C): ProductName = Synergis Adept Explorer 8.1 Property(C): ProductVersion = 8.2.16 Property(C): Manufacturer = Synergis Software Property(C): ReinstallFileOlderVersion = o |
Posted 16 November 2009 - 15:33
No, not near 'Fatal error', but around the first occurence of the text 'Return value 3.'
The scrollable thing...I was thinking of the other forum I frequent, AppDeploy.com, where I see you've posted the same question.
Edited by VBScab, 16 November 2009 - 16:39.
Posted 16 November 2009 - 16:32
Oops, sorry again.... Here's the surrounding lines of the .log....
The first instance... Action ended 13:28:40: InstallFinalize. Return value 3.
I hope this helps you or anyone to help me!!!
| MSI (s) (88:C4) [13:28:39:827]: Executing op: IniWriteRemoveValue(Section=HELP SolidModel,Key=FILE_de,Value=http://HS-PDM/jVue/help/de/smpro/AutoVueOnLineHelp.html,Mode=0) WriteIniValues: File: VueServer.ini Section: HELP SolidModel Key: FILE_de, Value: http://HS-PDM/jVue/h...OnLineHelp.html MSI (s) (88:C4) [13:28:39:827]: Executing op: IniWriteRemoveValue(Section=HELP SolidModel,Key=FILE_fr,Value=http://HS-PDM/jVue/help/fr/smpro/AutoVueOnLineHelp.html,Mode=0) WriteIniValues: File: VueServer.ini Section: HELP SolidModel Key: FILE_fr, Value: http://HS-PDM/jVue/h...OnLineHelp.html MSI (s) (88:C4) [13:28:39:843]: Executing op: IniWriteRemoveValue(Section=DMS,Key=DMS1,Value=http://HS-PDM:5098/servlet/SynergisDMS,Mode=0) WriteIniValues: File: VueServer.ini Section: DMS Key: DMS1, Value: http://HS-PDM:5098/servlet/SynergisDMS MSI (s) (88:C4) [13:28:39:843]: Executing op: IniWriteRemoveValue(Section=HELP,Key=FILE_en,Value=http://HS-PDM/jVue/help/en/pro/AutoVueOnLineHelp.html,Mode=0) WriteIniValues: File: VueServer.ini Section: HELP Key: FILE_en, Value: http://HS-PDM/jVue/h...OnLineHelp.html MSI (s) (88:C4) [13:28:39:843]: Executing op: IniWriteRemoveValue(Section=HELP,Key=FILE_de,Value=http://HS-PDM/jVue/help/de/pro/AutoVueOnLineHelp.html,Mode=0) WriteIniValues: File: VueServer.ini Section: HELP Key: FILE_de, Value: http://HS-PDM/jVue/h...OnLineHelp.html MSI (s) (88:C4) [13:28:39:859]: Executing op: IniWriteRemoveValue(Section=HELP,Key=FILE_fr,Value=http://HS-PDM/jVue/help/fr/pro/AutoVueOnLineHelp.html,Mode=0) WriteIniValues: File: VueServer.ini Section: HELP Key: FILE_fr, Value: http://HS-PDM/jVue/h...OnLineHelp.html MSI (s) (88:C4) [13:28:39:859]: Executing op: IniFilePath(File=AdeptExplorer.ini,Folder=C:\Program Files (x86)\Synergis\Adept Explorer\) MSI (s) (88:C4) [13:28:39:859]: Executing op: IniWriteRemoveValue(Section=USERSETTINGS,Key=MasterSite,Value=Adept,Mode=0) WriteIniValues: File: AdeptExplorer.ini Section: USERSETTINGS Key: MasterSite, Value: Adept MSI (s) (88:C4) [13:28:39:859]: Executing op: IniWriteRemoveValue(Section=USERSETTINGS,Key=MachineName,Value=HS-PDM,Mode=0) WriteIniValues: File: AdeptExplorer.ini Section: USERSETTINGS Key: MachineName, Value: HS-PDM MSI (s) (88:C4) [13:28:39:874]: Executing op: IniWriteRemoveValue(Section=USERSETTINGS,Key=WebCon,,Mode=0) WriteIniValues: File: AdeptExplorer.ini Section: USERSETTINGS Key: WebCon, Value: MSI (s) (88:C4) [13:28:39:874]: Executing op: IniWriteRemoveValue(Section=USERSETTINGS,Key=CurrentUser,,Mode=0) WriteIniValues: File: AdeptExplorer.ini Section: USERSETTINGS Key: CurrentUser, Value: MSI (s) (88:C4) [13:28:39:874]: Executing op: IniWriteRemoveValue(Section=USERSETTINGS,Key=Datasource,Value=Adept,Mode=0) WriteIniValues: File: AdeptExplorer.ini Section: USERSETTINGS Key: Datasource, Value: Adept MSI (s) (88:C4) [13:28:39:890]: Executing op: IniWriteRemoveValue(Section=USERSETTINGS,Key=VirDirFiles,Value=C:\inetpub\wwwroot\Adept\,Mode=0) WriteIniValues: File: AdeptExplorer.ini Section: USERSETTINGS Key: VirDirFiles, Value: C:\inetpub\wwwroot\Adept\ MSI (s) (88:C4) [13:28:39:890]: Executing op: IniWriteRemoveValue(Section=USERSETTINGS,Key=AEVersion,Value=8.2.16,Mode=0) WriteIniValues: File: AdeptExplorer.ini Section: USERSETTINGS Key: AEVersion, Value: 8.2.16 MSI (s) (88:C4) [13:28:39:890]: Executing op: ActionStart(Name=WiseVirtDirCallDll,,) Action 13:28:39: WiseVirtDirCallDll. MSI (s) (88:C4) [13:28:39:890]: Executing op: CustomActionSchedule(Action=WiseVirtDirCallDll,ActionType=3073,Source=BinaryData,Target=CreateWebSitesAndVDirs,) MSI (s) (88:80) [13:28:39:921]: Invoking remote custom action. DLL: C:\Windows\Installer\MSIB72.tmp, Entrypoint: CreateWebSitesAndVDirs WiseWeb: Action CreateWebSitesAndVDirs starting... WiseWeb: All website creation complete WiseWeb: Creating virtual directory/web directory (Adept) Action 13:28:39: CreateVDir. Creating Virtual Directory CreateVDir: Adept WiseWeb: Failed to create/update virtual directory correctly WiseWeb: Creating virtual directory/web directory (Adept/bin) Action 13:28:39: CreateVDir. Creating Virtual Directory CreateVDir: Adept/bin WiseWeb: Failed to create/update virtual directory correctly WiseWeb: Creating virtual directory/web directory (Adept/help) Action 13:28:39: CreateVDir. Creating Virtual Directory CreateVDir: Adept/help WiseWeb: Failed to create/update virtual directory correctly WiseWeb: All virtual directory/web directory creation complete WiseWeb: Memory clean-up complete WiseWeb: CreateWebSitesAndVDirs action ending Action ended 13:28:40: InstallFinalize. Return value 3. MSI (s) (88:C4) [13:28:40:015]: User policy value 'DisableRollback' is 0 MSI (s) (88:C4) [13:28:40:015]: Machine policy value 'DisableRollback' is 0 MSI (s) (88:C4) [13:28:40:015]: Executing op: Header(Signature=1397708873,Version=405,Timestamp=997026707,LangId=1033,Platform=0,ScriptType=2,ScriptMajorVersion=21,ScriptMinorVersion=4,ScriptAttributes=0) MSI (s) (88:C4) [13:28:40:015]: Executing op: DialogInfo(Type=0,Argument=1033) MSI (s) (88:C4) [13:28:40:015]: Executing op: DialogInfo(Type=1,Argument=Synergis Adept Explorer 8.1) MSI (s) (88:C4) [13:28:40:015]: Executing op: RollbackInfo(,RollbackAction=Rollback,RollbackDescription=Rolling back action:,RollbackTemplate=[1],CleanupAction=RollbackCleanup,CleanupDescription=Removing backup files...,CleanupTemplate=File: [1]) Action 13:28:40: Rollback. Rolling back action: MSI © (BC:0C) [13:28:40:015]: Note: 1: 2262 2: Billboard 3: -2147287038 Rollback: WiseVirtDirCallDll MSI (s) (88:C4) [13:28:40:031]: Executing op: ActionStart(Name=WiseVirtDirCallDll,,) MSI (s) (88:C4) [13:28:40:031]: Executing op: ProductInfo(ProductKey={7206BF5A-5261-4B95-B071-2BCD5BF576F7},ProductName=Synergis Adept Explorer 8.1,PackageName=AdeptExplorer.msi,Language=1033,Version=134348816,Assignment=0,ObsoleteArg=0,,,PackageCode={5140EFA0-8A30-4E49-99F1-0D1B848A6A44},,,InstanceType=0,LUASetting=0,RemoteURTInstalls=0,ProductDeploymentFlags=3) MSI (s) (88:C4) [13:28:40:031]: SHELL32::SHGetFolderPath returned: C:\Users\administrator.HOME-SHIELD\AppData\Roaming Rollback: Writing INI file values... MSI (s) (88:C4) [13:28:40:031]: Executing op: ActionStart(Name=WriteIniValues,Description=Writing INI file values...,Template=File: [1] Section: [2] Key: [3], Value: [4]) MSI (s) (88:C4) [13:28:40:031]: Executing op: IniFilePath(File=AdeptExplorer.ini,Folder=C:\Program Files (x86)\Synergis\Adept Explorer\) MSI (s) (88:C4) [13:28:40:031]: Executing op: IniWriteRemoveValue(Section=USERSETTINGS,Key=AEVersion,Value=8.2.16,Mode=2) MSI (s) (88:C4) [13:28:40:031]: Executing op: IniWriteRemoveValue(Section=USERSETTINGS,Key=VirDirFiles,Value=C:\inetpub\wwwroot\Adept\,Mode=2) MSI (s) (88:C4) [13:28:40:031]: Executing op: IniWriteRemoveValue(Section=USERSETTINGS,Key=Datasource,Value=Adept,Mode=2) MSI (s) (88:C4) [13:28:40:046]: Executing op: IniWriteRemoveValue(Section=USERSETTINGS,Key=CurrentUser,,Mode=2) MSI (s) (88:C4) [13:28:40:046]: Executing op: IniWriteRemoveValue(Section=USERSETTINGS,Key=WebCon,,Mode=2) MSI (s) (88:C4) [13:28:40:046]: Executing op: IniWriteRemoveValue(Section=USERSETTINGS,Key=MachineName,Value=HS-PDM,Mode=2) MSI (s) (88:C4) [13:28:40:046]: Executing op: IniWriteRemoveValue(Section=USERSETTINGS,Key=MasterSite,Value=Adept,Mode=2) MSI (s) (88:C4) [13:28:40:062]: Executing op: IniFilePath(File=VueServer.ini,Folder=C:\Program Files (x86)\jVue\bin\) MSI (s) (88:C4) [13:28:40:062]: Executing op: IniWriteRemoveValue(Section=HELP,Key=FILE_fr,Value=http://HS-PDM/jVue/help/fr/pro/AutoVueOnLineHelp.html,Mode=2) MSI (s) (88:C4) [13:28:40:062]: Executing op: IniWriteRemoveValue(Section=HELP,Key=FILE_fr,Value=http://hs-pdm.home-shield.com/jVue/help/fr/AutoVueOnLineHelp.html,Mode=0) MSI (s) (88:C4) [13:28:40:062]: Executing op: IniWriteRemoveValue(Section=HELP,Key=FILE_de,Value=http://HS-PDM/jVue/help/de/pro/AutoVueOnLineHelp.html,Mode=2) MSI (s) (88:C4) [13:28:40:062]: Executing op: IniWriteRemoveValue(Section=HELP,Key=FILE_de,Value=http://hs-pdm.home-shield.com/jVue/help/de/AutoVueOnLineHelp.html,Mode=0) MSI (s) (88:C4) [13:28:40:077]: Executing op: IniWriteRemoveValue(Section=HELP,Key=FILE_en,Value=http://HS-PDM/jVue/help/en/pro/AutoVueOnLineHelp.html,Mode=2) MSI (s) (88:C4) [13:28:40:077]: Executing op: IniWriteRemoveValue(Section=HELP,Key=FILE_en,Value=http://hs-pdm.home-shield.com/jVue/help/en/AutoVueOnLineHelp.html,Mode=0) MSI (s) (88:C4) [13:28:40:077]: Executing op: IniWriteRemoveValue(Section=DMS,Key=DMS1,Value=http://HS-PDM:5098/servlet/SynergisDMS,Mode=2) MSI (s) (88:C4) [13:28:40:093]: Executing op: IniWriteRemoveValue(Section=HELP SolidModel,Key=FILE_fr,Value=http://HS-PDM/jVue/help/fr/smpro/AutoVueOnLineHelp.html,Mode=2) MSI (s) (88:C4) [13:28:40:093]: Executing op: IniWriteRemoveValue(Section=HELP SolidModel,Key=FILE_de,Value=http://HS-PDM/jVue/help/de/smpro/AutoVueOnLineHelp.html,Mode=2) MSI (s) (88:C4) [13:28:40:093]: Executing op: IniWriteRemoveValue(Section=HELP SolidModel,Key=FILE_en,Value=http://HS-PDM/jVue/help/en/smpro/AutoVueOnLineHelp.html,Mode=2) MSI (s) (88:C4) [13:28:40:109]: Executing op: IniFilePath(File=allusers.ini,Folder=C:\Program Files (x86)\jVue\bin\) MSI (s) (88:C4) [13:28:40:109]: Executing op: IniWriteRemoveValue(Section=MRKFONT,Key=FACE,Value=SansSerif,Mode=2) MSI (s) (88:C4) [13:28:40:109]: Executing op: IniWriteRemoveValue(Section=MRKFONT,Key=ISITALIC,Value=0,Mode=2) MSI (s) (88:C4) [13:28:40:124]: Executing op: IniWriteRemoveValue(Section=MRKFONT,Key=ISUNDERLINE,Value=0,Mode=2) MSI (s) (88:C4) [13:28:40:124]: Executing op: IniWriteRemoveValue(Section=MRKFONT,Key=SIZE,Value=22,Mode=2) MSI (s) (88:C4) [13:28:40:140]: Executing op: IniWriteRemoveValue(Section=MRKFONT,Key=ISBOLD,Value=0,Mode=2) MSI (s) (88:C4) [13:28:40:140]: Executing op: IniWriteRemoveValue(Section=PENSETTINGS,Key=PEN0,Value=alt1,0= 0.01,1= 0.01,2= 0.01,3= 0.01,4= 0.01,5= 0.01,6= 0.01,7= 0.01,8= 0.01,9= 0.01,10= 0.01,11= 0.01,12= 0.01,13= 0.01,14= 0.01,15= 0.01,16= 0.01,17= 0.01,18= 0.01,19= 0.01,20= 0.01,21= 0.01,22= 0.01,23= 0.01,24= 0.01,25= 0.01,26= 0.01,27= 0.01,28= 0.01,29= 0.01,30= 0.01,31= 0.01,32= 0.01,33= 0.01,34= 0.01,35= 0.01,36= 0.01,37= 0.01,38= 0.01,39= 0.01,40= 0.01,41= 0.01,42= 0.01,43= 0.01,44= 0.01,45= 0.01,46= 0.01,47= 0.01,48= 0.01,49= 0.01,50= 0.01,51= 0.01,52= 0.01,53= 0.01,54= 0.01,55= 0.01,56= 0.01,57= 0.01,58= 0.01,59= 0.01,60= 0.01,61= 0.01,62= 0.01,63= 0.01,64= 0.01,65= 0.01,66= 0.01,67= 0.01,68= 0.01,69= 0.01,70= 0.01,71= 0.01,72= 0.01,73= 0.01,74= 0.01,75= 0.01,76= 0.01,77 MSI (s) (88:C4) [13:28:40:156]: Executing op: IniWriteRemoveValue(Section=PENSETTINGS,Key=SELECTEDPEN,Value=alt1,Mode=2) MSI (s) (88:C4) [13:28:40:171]: Executing op: IniWriteRemoveValue(Section=PENSETTINGS,Key=PEN1,Value=alt2,0= 0.05,1= 0.05,2= 0.05,3= 0.05,4= 0.05,5= 0.05,6= 0.05,7= 0.05,8= 0.05,9= 0.05,10= 0.05,11= 0.05,12= 0.05,13= 0.05,14= 0.05,15= 0.05,16= 0.05,17= 0.05,18= 0.05,19= 0.05,20= 0.05,21= 0.05,22= 0.05,23= 0.05,24= 0.05,25= 0.05,26= 0.05,27= 0.05,28= 0.05,29= 0.05,30= 0.05,31= 0.05,32= 0.05,33= 0.05,34= 0.05,35= 0.05,36= 0.05,37= 0.05,38= 0.05,39= 0.05,40= 0.05,41= 0.05,42= 0.05,43= 0.05,44= 0.05,45= 0.05,46= 0.05,47= 0.05,48= 0.05,49= 0.05,50= 0.05,51= 0.05,52= 0.05,53= 0.05,54= 0.05,55= 0.05,56= 0.05,57= 0.05,58= 0.05,59= 0.05,60= 0.05,61= 0.05,62= 0.05,63= 0.05,64= 0.05,65= 0.05,66= 0.05,67= 0.05,68= 0.05,69= 0.05,70= 0.05,71= 0.05,72= 0.05,73= 0.05,74= 0.05,75= 0.05,76= 0.05,77 MSI (s) (88:C4) [13:28:40:171]: Executing op: IniWriteRemoveValue(Section=PENSETTINGS,Key=UNITS,Value=0,Mode=2) MSI (s) (88:C4) [13:28:40:187]: Executing op: IniWriteRemoveValue(Section=PRINTWATERMARK,Key=FONTSTYLE,Value=0,Mode=2) MSI (s) (88:C4) [13:28:40:187]: Executing op: IniWriteRemoveValue(Section=PRINTWATERMARK,Key=ORIENTATION,Value=0,Mode=2) MSI (s) (88:C4) [13:28:40:187]: Executing op: IniWriteRemoveValue(Section=PRINTWATERMARK,Key=FONTNAME,Value=Arial,Mode=2) MSI (s) (88:C4) [13:28:40:187]: Executing op: IniWriteRemoveValue(Section=PRINTWATERMARK,Key=FONTSIZE,Value=28,Mode=2) MSI (s) (88:C4) [13:28:40:202]: Executing op: IniWriteRemoveValue(Section=PRINTWATERMARK,Key=TEXT,Value=%X<Watermark>,Mode=2) MSI (s) (88:C4) [13:28:40:202]: Executing op: IniWriteRemoveValue(Section=PRINTHEADERS,Key=BOTTOMRIGHTTEXT,Value=%p of %n,Mode=2) MSI (s) (88:C4) [13:28:40:202]: Executing op: IniWriteRemoveValue(Section=PRINTHEADERS,Key=TOPCENTERTEXT,Value=%X<FileNE>:%X<Watermark>,Mode=2) MSI (s) (88:C4) [13:28:40:218]: Executing op: IniWriteRemoveValue(Section=Options,Key=AIBACKGROUND,Value=0,Mode=2) MSI (s) (88:C4) [13:28:40:218]: Executing op: IniFilePath(File=csireg.ini,Folder=C:\Program Files (x86)\jVue\bin\) MSI (s) (88:C4) [13:28:40:218]: Executing op: IniWriteRemoveValue(Section=Registration,Key=Serial Number,Value=353-756-0000000-30,Mode=2) MSI (s) (88:C4) [13:28:40:218]: Executing op: IniWriteRemoveValue(Section=Registration,Key=Serial Number,Value=353-756-0000000-30,Mode=0) MSI (s) (88:C4) [13:28:40:218]: Executing op: IniWriteRemoveValue(Section=Registration,Key=ServicePack,Value=1,Mode=2) MSI (s) (88:C4) [13:28:40:234]: Executing op: IniWriteRemoveValue(Section=Registration,Key=ServicePack,Value=1,Mode=0) MSI (s) (88:C4) [13:28:40:234]: Executing op: IniWriteRemoveValue(Section=Registration,Key=Company,Value=HOMESHIELD,Mode=2) MSI (s) (88:C4) [13:28:40:234]: Executing op: IniWriteRemoveValue(Section=Registration,Key=Company,Value=Microsoft,Mode=0) MSI (s) (88:C4) [13:28:40:234]: Executing op: IniWriteRemoveValue(Section=Registration,Key=License,Value=P=CS&T=CONC&B=AV3DP&FC=Office:LH,2D:LH,3D:LH&N=100000&TO=1200&IP=127.0.0.1&I=2007/10/17&V=2017/10/14&SN=353-756-0000000-30&RL=19.3&C=1572157462,Mode=2) MSI (s) (88:C4) [13:28:40:234]: Executing op: IniWriteRemoveValue(Section=Registration,Key=License,Value=P=CS&T=CONC&B=AV3DP&FC=Office:LH,2D:LH,3D:LH&N=100000&TO=1200&IP=127.0.0.1&I=2007/10/17&V=2017/10/14&SN=353-756-0000000-30&RL=19.3&C=1572157462,Mode=0) MSI (s) (88:C4) [13:28:40:249]: Executing op: IniWriteRemoveValue(Section=Registration,Key=User,Value=Troy Olson,Mode=2) MSI (s) (88:C4) [13:28:40:249]: Executing op: IniWriteRemoveValue(Section=Registration,Key=User,Value=Microsoft,Mode=0) Rollback: Writing system registry values... MSI (s) (88:C4) [13:28:40:249]: Executing op: ActionStart(Name=WriteRegistryValues,Description=Writing system registry values...,Template=Key: [1] Name: [2] Value: [3]) MSI (s) (88:C4) [13:28:40:249]: Executing op: |
Posted 16 November 2009 - 16:36
| Action 13:28:39: CreateVDir. Creating Virtual Directory CreateVDir: Adept WiseWeb: Failed to create/update virtual directory correctl |
Abandon the brain-dead Wise Custom Actions. I have never yet used them and had them completely successfully. At one client - who was adamanat we should use them, a colleague and I spent almost a week running tests and never really got to the bottom of why they failed.
Use the IIS-bundled VBSs instead. They're much more reliable and as they're scripts, you can edit them so that they can output information (e.g. errors!) to the MSI log.
Posted 16 November 2009 - 17:43
Adding the IIS 6 compatibility pack solved our problem. That was easy enough. Not I have to tweak my install wrapper or the installation .msi itself to detect the absence of this and warn.
