hello guys,
ok, i am trying to launch two programs from my postinstall script but i cant seem to get it to work properly .. if i try and start only one of the programs, it works fine but if i include the second one, the second one starts before the first one ( this is not good as the second one is dependant on the first one and as such the program installation fails ) .. how can i do this ?? any ideas ??
here's a look at my code so if anyone could help me out, i would appreciate it .. ill keep looking into finding the solution myself so ill keep this posted if i find an answer ..
thanks guys
LaunchAppAndWait function ??
mila
, Oct 22 2007 08:08
Posted 22 October 2007 - 08:08
szFile = INSTALLDIR ^ "mila.exe"; if ( LaunchAppAndWait ( szFile , "", NOWAIT ) < 0) then MessageBox ("Unable to launch "+ szFile +".",SEVERE); endif; szFile1 = INSTALLDIR ^ "mila_2.exe"; if ( LaunchAppAndWait ( szFile1 , "", NOWAIT ) < 0) then MessageBox ("Unable to launch "+ szFile1 +".",SEVERE); endif; |
Posted 22 October 2007 - 09:39
hey guys,
i found a work around for this .. added a couple of several dialog windows so that after the first application is installed, you have to press OK in order for the second application to be executed ..
not a great solution but does the job ..
Posted 24 October 2007 - 14:21
NOWAIT doesn't wait for the first program to finish. So it start the first and then immediately the second program, so the two programs run essentially at the same time.
