Hi mallen
here's a kind of code snippet i played around with some time ago. I didn't manage to get it run corrctly, but i didn't knew that i have to have a dialog twin to update the controls....
Anyway it's a VB Script CA code... you have to write your list values into the specific MSI table, and i suppose afterwards switch to the dialog twin... the step that i missed obviously when i tried that stuff.
The code might not be correct in each line, but i guess it will give you an idea of what you need to do.
Cheers
Stefan
Public Function AppendListBox () Dim oDatabase Dim oView Dim oInstaller
Dim oRecord Dim intCount Dim oRecordErr
On Error Resume Next
Set oDatabase = Session.Database
Set oView = oDatabase.OpenView("SELECT * FROM ListBox")
If oView Is Nothing Then Set oDatabase = Nothing Exit Function End If
Set oInstaller = Session.Installer
'Each record will have four columns. First is the property, second an id 'third to the value and the fourth to the key Set oRecord = oInstaller.CreateRecord(4)
If Not oRecord Is Nothing Then 'Set the property of the control to which the records are to be attached oRecord.StringData(1) = "MYPROPERTY" oRecord.IntegerData(2) = id '(integer) oRecord.StringData(3) = "value" oRecord.StringData(4) = "key" End If
On Error Resume Next 'Read/Write on to the view oView.Modify 7,oRecord
Set oRecord = Nothing
Set oRecordErr = oInstaller.LastErrorRecord
If Not oRecordErr Is Nothing Then For intCount = 0 to oRecordErr.FieldCount ShowError oRecordErr.StringData & " " & oRecordErr.IntegerData Set oRecordErr = Nothing Exit Function Next End If
oView.Close Set oView = Nothing Set oDatabase = Nothing Set oInstaller = Nothing Set oRecord = Nothing Set oRecordErr = Nothing
End Function
