anyone knows how to remove the "Logging started ..... bla bla" message which appears the first time you run a package on a machine on which it isnt installed before ?
Its annoying, coz the setup suddenly exits after that box and you have to run it again.
The probleam appears just once, the next time the package is run the setup works correctly. I tried to search everywhere on the net but havent found anything about that. I hope i'm not the only one who suffer this problem
I'm using IS Developer 7.04 and working with standard projects using MSI 2.0
Hope to see an answer
Valerio
