Hi,all.
I 'm the new on InstallShield 11.5 .
I met the following problem.
i called OnFirstUIBefore() ,OnMaintUIBefore() and OnMaintUIAfter() functions
in my installScript. And i found that if i didn't call OnMaintUIBefore(),
the Add/Remove control panel's perform is OK.If i called OnMaintUIBefore(),
the modify button will calls SdWelcomeMaint dialog. That's OK.But the remove button
also calls SdWelcomeMaint dialog. i don't know what's wrong with it....
Any ideas as to what I can do to make it run properly?
Thank u very much....
the source structure is....
function OnFirstUIBefore()
begin
end;
function OnMaintUIBefore()
begin
nType = SdWelcomeMaint(szTitle, szMsg, MODIFY);
if (nType = REMOVEALL) then
svResult = SdLoadString(IFX_MAINTUI_MSG);
szCaption = SdLoadString(IFX_ONMAINTUI_CAPTION);
nResult = SprintfBox(MB_OKCANCEL,szCaption,"%s",svResult);
if (nResult = IDCANCEL) goto Dlg_Start;
endif;
nResult = NEXT;
Dlg_SdFeatureTree:
if (nType = MODIFY) then
szTitle = "";
szMsg = "";
nResult = SdFeatureTree(szTitle, szMsg, INSTALLDIR, "", 2);
if (nResult = BACK) goto Dlg_Start;
endif;
switch(nType)
case REMOVEALL: FeatureRemoveAll();
case REPAIR: FeatureReinstall();
endswitch;
end;
Add/Remove control panel's problem
installshielduan
, Apr 06 2006 17:14
Posted 12 April 2006 - 16:36
Try the following:
if( !REMOVEONLY ) then // In standard mode show maintenance dialog Disable( BACKBUTTON ); nType = SdWelcomeMaint( szTitle, szMsg, nType ); Enable( BACKBUTTON ); nResult = NEXT; else // Hide the initial progress dialog as otherwise the user can // click on it, and hide the MessageBox. Disable( DIALOGCACHE ); // In RemoveOnly mode, set to remove. nType = REMOVEALL; endif; |
I think the part you're missing is checking REMOVEONLY
-- spdygnlz --
