I need anybody help.
Does selection tree is only can be used in install case only in Basic MSI? How about in uninstall case. Is it possible to use in uninstall condition?
Please help me.
Selection Tree control
anastasia
, Nov 08 2011 10:55
Posted 11 November 2011 - 19:15
By default, the selection tree dialog is displayed during first time install and in maintenance mode if user selects the Modify option. You could also insert it in the dialog sequece for the Remove option, however:
- it doesn't make much sense to select features when your setup is performing a complete uninstall (all features will be removed, so why select?)
- it would only be displayed if user selects Modify from control panel and then the Remove option. If they select the Remove button in control panel, the uninstall will run in Basic UI mode and therefore won't display your authored UI dialogs.
