I am trying to determine if my program is compatible with user's system. I am looking for a version of a file but only interested in its major version. How can I use VerCompare without including the minor version information.
VerGetFileVersion ( svValue ^ "winword.exe" , svVersionNumber );
nResult = VerCompare ("10.0", svVersionNumber, VERSION);
Thank you.
compare major version
vaqueros
, Jul 01 2004 18:53
Posted 02 July 2004 - 02:44
Well one way to do this would be to use the call StrGetTokens to break svVersionNumber at the decimal points to get a list of the major, minor, fix, build numbers. See the help for more information about then this call.
Then, at that point, you can just do a straight VerCompare of "10" to that 1st major token.
Posted 02 July 2004 - 08:51
Another option would be to perform two comparisons to see if its in the range between 10.0.0.0 and 10.9999.9999.9999
Posted 02 July 2004 - 16:34
| QUOTE (Taco Bell @ 2004-07-01 21:44) |
| Well one way to do this would be to use the call StrGetTokens to break svVersionNumber at the decimal points to get a list of the major, minor, fix, build numbers. See the help for more information about then this call. Then, at that point, you can just do a straight VerCompare of "10" to that 1st major token. |
Thank you for the reply.
When I tried this method I was getting mixed results. When populating a list with the StrGetTokens I was getting the correct list (below).
10
0
6612
0
But when I tried to retrieve the first item I was getting weird results. Using "ListGetFirstItem" I always get "0" and using "ListGetFirstString" I would alwyas get "28579376".
I'm not sure what I'm doing wrong.
RegDBSetDefaultRoot ( HKEY_LOCAL_MACHINE );
szKey = "Software\\Microsoft\\Office\\10.0\\Word\\InstallRoot";
szName = "Path";
nType = REGDB_STRING;
RegDBGetKeyValueEx ( szKey , szName , nvType , svValue , nvSize );
listID = ListCreate (STRINGLIST);
StrGetTokens (listID, svVersionNumber, ".");
nResult = SdShowInfoList ("List Versions", "Test", listID);
ListGetFirstString (listID, svListString);
SprintfBox (INFORMATION, "List Item", "%i", svListString);
Posted 02 July 2004 - 16:52
| QUOTE (Stefan Krueger @ 2004-07-02 03:51) |
| Another option would be to perform two comparisons to see if its in the range between 10.0.0.0 and 10.9999.9999.9999 |
This looks like an easier solution but I'm not sure how to limit the range though. It seems by doing both comparisons I am allowing incompatible versions to run.
nResult = VerCompare ( "10.0.0.0" , svVersionNumber , VERSION );
if (nResult = GREATER_THAN) then
szMsg = "The setup program was not able to determine that you have \n" +
"a compatible version of Microsoft Office installed.\n\n" +
"Click on the Next button to exit this program.";
MessageBox ( szMsg , WARNING );
szMsg = "The setup program will now exit.\n\n" +
"No files were installed in your system.";
MessageBox ( szMsg , INFORMATION );
abort;
elseif (nResult = LESS_THAN) then
nResult = VerCompare ( "10.9999.9999.9999" , svVersionNumber , VERSION );
szMsg = "Version accepted";
endif;
endif;
Posted 02 July 2004 - 20:50
Well for your first attempt, the SprintfBox should be "%s", not "%i" because it's a string value and not a straight decimal value. 'cause remember all you've done is broken up the version string into a bunch of substrings.
For your second attempt, perform the two comparisons back to back (e.g. "10.0.0.0" and "10.9999.9999.9999" respectively) to get two results, then make sure nResult1 is not LESS_THAN and that nResult2 is not GREATER_THAN. This is to ensure that a version of say exactly "10.0.0.0" is properly accepted. Code wise, the comparison would work out to the following:
| nResult1 = VerCompare("10.0.0.0", svVersionNumber, VERSION); nResult2 = VerCompare("10.9999.9999.9999", svVersionNumber, VERSION); if (nResult1 != LESS_THAN && nResult2 != GREATER_THAN) then // VERSION ACCEPTED MessageBox("Version accepted.", INFORMATION); else // VERSION UNACCEPTABLE MessageBox("ERROR: Version unacceptable.", SEVERE); endif; |
Hope it helps.
