How to create a check boxes in dialog dynamically from reading a file to get the list of items to be displayed?
Ex. I have about 150 items to be displayed in a dialog box as check box selectable from reading a file.
can this be done?
Also what is the limitation of # of features you can create in a IS 12 professional project?
how to create check box dialog dynamically?
yp_patel
, Jun 09 2009 15:30
Posted 09 June 2009 - 15:46
You can create a "script created feature set" using FeatureAddItem and then use SdAskOptionsList.
Posted 11 June 2009 - 14:03
SdAskOptionList shows very small window screen, and it would be too difficult for user to navigate through 150 to 200 items.
Is there a way I can show bigger screen and in multiple columns in same screen for user to select?
Posted 12 June 2009 - 12:16
You can modify the dialoh in the dialog editor. Not sure if the control supports multi column though.
