MergeModule Installation
Posted 20 October 2001 - 06:27
I want to Install MSXML3 MergeModule Conditionally.ie if msxml3.dll is in the target machine, setup shouldnot install the merge module.If not it should install it. I am not sure whether it is possible or not.I am Using ISWI 2.01. Pl reply.
Posted 20 October 2001 - 20:06
1. Use the AppSearch table (together with Signature and DrLocator) to find the msxml3.dll
2. Add the merge module to a feature with a condition based on the search results from step 1.
Posted 31 October 2001 - 11:49
i tried the way u told.but it doesnot give the result. ie here i am giving the
porcedure that i done.
Signature Table
SignatureFileName
MSXMLDLLmsxml3.dll
APPSearch Table
PropertySignature
MYAPPMSXMLDLL
DRLocator Table
SignatureParentPathDepth
MSXMLDLLC:\Winnt\System32 0
Then i add one feature namely MSXMLDLL
Install Level for this is 101.
Using the Condition Builder i made the followings
Condition is MYAPP=C:\Winnt\System32
Level is 99
so when the setup run it will search for the dll .if found it should set the MYAPP Property
to C:\Winnt\System32. so the condition becomes TRUE.so the MSXML.msm should be installed.
because the install level is less than 100.
But here the MM is not installed.i think the Property is not set to C:\Winnt\System32.
Pl tell me where i am making mistake.
Posted 07 November 2001 - 16:02
Posted 12 November 2001 - 11:43
You could both use Orca and ISWI.
good luck
Posted 24 November 2001 - 05:54
I donot know how to edit the condition of a MM.Am Using ISWI2.01.
Is it Possible to open and edit a MM
reply Please
Posted 20 December 2001 - 16:49
MSDE merge module is always installed.
