Does anyone know if it is possible to enable "Warnings as errors" in a command line compile? Or how to pick up the warnings in a batch file?
HOW TO enable "Warnings as errors" in command line
vuttex
, Sep 18 2002 15:20
Posted 18 September 2002 - 17:02
I don't do command line compiles yet, but FWIW from the IDE go to Build | Settings, choose the Compile/Link tab, and check "Warnings as errors".
Posted 20 September 2002 - 13:43
Yes I know this! But it does not help me in command line. I have also tried to add this in the GUI and then used the export batch file. But this does not work. Checking the "Warnings as errors" does not get exported to the batch file.
Posted 20 September 2002 - 17:36
Okay, well that's what I had the disclaimer of FWIW (For What It's Worth).
I defer then to all those command line builders out there.
