I have installed say ProductVersion1.msi from the location D:\Installs\ with product version 1.0.10
After installation i have deleted the file ProductVersion1.msi from the location D:\Installs\
I now have a patch Patch2.msp whose version number is 1.0.20. I am applying the patch using the following command
Network Resource unavailable when applying Patch.
satishb
, Dec 13 2004 08:41
Posted 13 December 2004 - 08:41
| msiexec /p Patch2.msp REINSTALL=ALL REINSTALLMODE=omus |
the patch application starts and throws a message box saying
The feature you are trying to use is on a network resource that is unavailable. Click OK to try again, or enter an alternate path to a folder containing the installation package 'ProductVersion1.msi' in the box below. |
The box contains the location D:\Installs\ProductVersion1.msi
Why does the Windows Installer look at the location from where the product was installed instead of taking the Cached Version ?
How do i instruct the Windows Installer to use the Cached Copy instead of looking the msi in the location from where it is installed ?
Regards,
-Satish
Posted 14 December 2004 - 11:14
The cache only includes the MSI database, not your application files. There are various possible reasons why a patch may require the original source. Did you read topic "How can I prevent my patch from requiring access to the original installation source?" in MSI Help? Using MSI 3 instead of MSI 2 should also improve the situation.
