I am using FileBrowseDlg() in my CA (for the function, refer to InstallShield kb Q104325 and Q102579, go to http://support.installshield.com/kb/ search the article numbers), The browse dlg works - I can browse the txt file from my local drive, but the function returns empty file path/name in the msgbox. I step through FileBrowseDlg() and found after calling GetOpenFileNameA(&ofn), the 'szFile' is still empty, I expected it to change from empty to whatever I selected path/name, am I right? Anybody knows why and how to fix it?
Here is my simple CA, which follows the sample function in the article:
function browseLicense(hMSI)
STRING svFile[260];
NUMBER nReturn;
begin
if(MODE=SILENTMODE) then
//do silent mode license checking...
else
nReturn = FileBrowseDlg(svFile, 260, "Text files (*.txt)\0*.txt\0\0",
"Browse for license file", WINDISK, FALSE, NULL, FALSE);
endif;
if (nReturn=0) then
MessageBox("File is " + svFile, 0);
else
MessageBox("Error happens!", 0);
endif;
end;
Peter
