Hi there, is it possible to create a custom action to call a dll function with one or more parameters? The msdn documentation says that the prototype for the dll function you can call has to be UINT __stdcall MyDllFunction(MSIHANDLE hMsi).
Is there a way to have a function like UINT __stdcall MyDllFunction(MSIHANDLE hMsi, string param1, int param2)?
Pass parameter to custom action 17
dbcn
, Feb 06 2008 22:59
Posted 07 February 2008 - 00:16
That's not possible.
The preferred solution is to have the exported function ask for the extra parameters, using MsiGetProperty(). This solution assumes that the parameters can be stored inside a property, meaning that they can be represented by a string. Usually that is not a problem.
