i've 2 features, some components are installed in a network path, when windows finish the start process (after login) and the UNC path isn't available starts the repair process. It's fine? or exists any way to solve this problem?.
If the repair process starts when i run the installed application, its fine.... but i only starts windows.
System: Windows 2000 Pro with SP3
InstallShield: 2.03 for WI
Maradoo.
Repair starts after reboot
Maradoo
, Apr 11 2003 14:11
Posted 14 May 2003 - 12:07
Maradoo,
It sounds like you have an application running from source on the network?
Does the repair kick off when you run it up with the same account that you installed with? Or is this with a different account? It sounds like it's maybe the Per-User data being repaired.
If it's asking for the network source, and there are Per-User files I'd say that was where your problem is.
If I've missed the point completely and am on the wrong track, I would suggest you use the Event Log to get further information on the repair.
Cheers
Adam :-)
Cheers
Adam :-)
